gregbowler
Everything posted by gregbowler
  1. Stock carbs need new floats and needle and seats, Should I spend the money to fix them or get the PWK knock offs?
  2. windex and really fine steel wool
  3. DMC for sure. (they sound bad ass)
  4. has not set their status
  5. bump
  6. I have an airbox with a aluminium pro-flo adapter and K&N w/outerware i'll sell for 35+ shipping
  7. new style/ square plug
  8. gregbowler
    Need Stator
    1.5 year old ricky stator is making my motor break-up. Need replacement. Post or PM me. Thanks
  9. Just trying to tune my new motor and have a lean pop and more smoke or steam out of the right (clutch) side. Motor will hold 6 psi overnight. Carbs are in sync, have tool. So what do you think ? Are these domes leaking coolant ? mods are as follows : 4mil stock cylinder HJR dune port 795 pro lite pistons 65mm bore Noss Head with custompump gas stroker domes DMC916 pipes stock carbs carbon tech reeds stock cages jetted 27.5 pilot 1 turn out 330 main middle clip on the needle http://i1182.photobucket.com/albums/x446/gregbowler/P1000404.jpg http://i1182.photobucket.com/albums/x446/gregbowler/P1000402.jpg http://i1182.photobucket.com/albums/x446/gregbowler/P1000403.jpg http://i1182.photobucket.com/albums/x446/gregbowler/P1000401.jpg
  10. Wouldn't the DMC 916's be good for this application as well ? They are a monster in the midrange.
  11. My adapter is aluminium and seals with a large oring. Never leaked before.
  12. Yup. Thats what I use.
  13. Time to fix my leaking stock pipe clamps on my dmc pipes and was wondering what aftermarket billet clamps will fit my pipes. I see clamps for lots of other pipes listed , but none for the dmc's. Any help ? Thanks
  14. my guess is the main jet rattled out in the bowl
  15. looks right to me
  16. My bad... The duh was directed at this. I quoted the wrong post so duh on me.
  17. duh :laugh:
  18. This sounds backwards to me
  19. I would bump up the mains to at least a 260 and pilots to 27.5 or 30. Running a stock main jet with aftermarket pipes is asking for a lean burn down. It idleing up when the choke is pulled is a clear sign it's lean.
  20. I'll be there fri,sat,sun white chevy with a tent in the bed, Black and red shee.
  21. The 916's sound like a street bike in my opinion. I have them.
  22. belray gear saver 80wt
