Motoman
Motoman's Achievements
  1. Im not much above sea level and I did warm it up alittle before I checked it. I did keep kicking it until it didnt go up anymore. Do you think just a new set of rings would do the trick?.
  2. Hi guys, I just bought a 1997 Banshee YZ350. I noticed it smokes alot so I did a compression test. It was alittle less then 90 psi in both cylinders. Is that too low to just replace the rings and have it be ok or does it need to be bored out. Please let me know. Thanks, John
  3. Could someone please tell me what exactly a plug chop is?.
  4. Do you have the link for Vito's?.
  5. I just ordered a compression tester. It has a 14mm adaptor and a 18mm adaptor. Which size will fit the Banshee?. Thanks
  6. Thanks for the info. Im new at this Quad thing. I always had Motocross bikes. I hope I dont sound like too much of a dope but was is Plug Chopping?.
  7. Hey Guys, I have a 97 Banshee. Does anyone have an idea of what the stock compression should be?. Whats the lowest it should be before I need new rings?. Does anyone know where I can get a good compression tester for it?. Thanks
  8. Thanks for the info!
  9. My elevation is not very high from sea level and I wont be riding in temps under 50 degrees. Would the #25 do it?.
  10. I do have #280 mains and #30 pilots. Would this be ok or do you strongly recommend the #270 main and #25 pilot?. Whatever you think is best.
  11. Wow, Thanks I thought it was the other way around.
  12. I do have #280 mains and #30 pilots. Would this be ok or do you strongly recommend the #270 main and #25 pilot?. Whatever you think is best.
  13. Hi guys, I just bought a carb kit. I noticed the stock needles have 6 notches in them but the new ones have only five. Now for example if my clip is on the 4th notch on the stock needle, what notch should it be on for the new one?.
  14. Thanks for all your help guys. Im glad you guys are here. I'll let you know how I make out. John
  15. Even with the Bill's aftermarket pipes should I go back to those sizes?.
