gregbowler
Everything posted by gregbowler
  1. or a water pump seal
  2. what elevation and temps? Reguardless 200 is small for a bike with aftermarket pipes.
  3. Sounds like not enough toe in or too little caster
  4. I take off the caps and lightly squeeze them with pliers so they are just out of round then screw them on. Never lost one yet. Also I would think locktite would be a bad idea. It's not conductive and could isolate the cap from the plug.
  5. Here's a pic I found of a modded star:
  6. motul 800 @ 50:1
  7. Final Update Here are some pics of the final installation. I rode it today for the first time. It looks and rides great. Way more stabil. Thanks for all the help everyone :biggrin:
  8. less preload will lower it. i.e take tension off the spring to lower
  9. +1 good pipes
  10. They would be very very stiff but would fit
  11. Try Here: http://www.sudco.com/
  12. The link is bad
  13. Still $295 http://www.ngk.com/results_cross.asp?pid=91101&s=10
  14. :yelrotflmao: :yelrotflmao: :yelrotflmao: Ya he's very young
  15. A backfire is most likely lean. I would check for air leaks
  16. It may run good but it won't run for long. Jet it up to toomey's specs if not higher
  17. I disagree never had any problems with my 97. The only advantage to an aftermarket one is some are higher output. (i.e more lights)
  18. Could just be mis-adjusted floats also.
  19. Looks like this one: http://www.magicracing.com/Pro-Aluminum-V-..._p_116-647.html
  20. 220-230 main stock needle and pilot
  21. Here are some pics I just took:
  22. Thats why you burned it down. I would go with the suggested 320 and 27.5 pilot. The pilot screws out with a small flat head
  23. My boots have saved me more than once :biggrin:
  24. I would also check the water pump impeller and bearing. The stock impellers are plastic and can break
  25. The pilot and screw only effect idle to 1/8 throttle. Out on the screw is more air in is less air,(at idle-1/8) Try 1-1 1/2 turns out from lightly seated all the way in.
