Ok, i'll try an give a little more info but i need to know what you need to know. i tried bumping my mains up to 310's today as i want it a little richer, i also dropped my pilots to 25's but now i have to keep them screwed in tight to keep it idiling, if i back them out even 1 turn my idle drops to nothing, 2turns an it just doesnt want to run period unless i pull the choke out just a hair, like i mentioned before,are these pilot circuits that touchy that i cant get a 30 or a 25 to run proper and i need a 27.5??? i feel the bike runs great from mid to topend, i just seem to be havin problems setting my idle and initial throttle response {hesitation/ bogginess}
In case it helps to solve the problem i do have the TORS still, but unhooked , also im trying to not use the set screws on top of the TORS to help set my idle as ive heard this isnt the proper procedure an it seems to effect the way the motor runs,{in a bad way}, should i be tryin to just use my air screws for idle adjustment or can i monkey with it up at the thumb throttle cable and on top of left TORS without worries??? sorry to ramble on, thanks again for your help and opinions
