trex banshee
Everything posted by trex banshee
  1. I don't call mine anything but my buddy has one that he calls "Dollar", because he has a lot of money in it. and then another one that has identical plastic that he calls "50", cause it cost alot less than his first one did.
  2. I don't know about putting anything other than four wheeler shocks on the front but I have a QA1 proma star coil over for my rear. You can make fun all you want. Call it redneck i don't give a shit, all i know is it works great and has 12 settings and holds my 300lbs up with plus 6 swingarm awesome. I can turn it to 8 and it is completely solid and i usually run it at 4 for normal riding and it feels just like any other banshee. Here are some pics. I have I think $230 in the shock and spring brand new from JEGS.
  3. I'll be there this weekend!! :beer:
  4. hey man i am not interested in buying anything but thought i would help if you couldn't figure out the pics. Just email them to me at [email protected]
  5. the H129 crank i believe is the 4 mill stroker with 5mm long rods. If i were you check your squish clearence. To do this just get a soft peice of solder and put it in the cylinder so when you turn the engine over by hand it will smash the solder, then mic the smashed part of the solder. I was told that they run best between .032 and .048 thousandths. Lots of builders have their own preference though. Just check this so we can get a good ballpark number.
  6. you got any pics of the engine and cylinders. They are stock port right?
  7. are you parting the engine out also, or is it gonna be sold complete??
  8. Both mine and my brothers rockets are even on both sides. Are you sure that you don't have one pipe mounted on the inside of the bracket and the other pipe is mounted on the outside of the bracket?
  9. steel wool and WD40, works really good another redneck way to clean shit is...alot won't believe me but, Coke and aluminum foil.
  10. I always ran HP2 in my bike which is 100% synthetic and then when i switched to alcohol i had to start running castor 927. Castor mixed with alky smells......well different, but i guess anything mixed with alcohol smells different. :biggrin:
  11. Do you know what bore the cylinders are on?
  12. aren't there more rules to breaking the top speed other than just getting there and your done. I heard you have to do it like 3 times and hold the speed for a certain distance. if this is so its probably why the shee isn't at the top, we all know that it could beat this top speed but not three times in a row and for a long distance. not 100% sure but just what I heard.
  13. yeah i agree with big blue, it wasn't hard at all. Just some lube and a socket that is the same size as the outside of the seal and it goes right in. on another note its not crank seals, they don't hold coolent out. Another thing that it could be is the little o-ring that is on the metal pipe that your side case pops over. This goes bad before your water pump seal does, but when it goes bad it lets more coolent flow outside and on top of your cases rather than in your oil. If I were you check the oring first, then if it checks out allright go to the water pump seal.
  14. Was a good deal no funny stuff, second time i have done business with him and will do it again for sure, arrived right on time like promised. thanks again Thomas
  15. I think he may be talking about the right crank seal. And if it is bad it will burn the oil out of the tranny case. And if this is so it will make it run like shit on the right cause it is burning so much oil. If it was mine i wouldn't ride it.
  16. yeah those are old fmf's.
  17. what kind of fmf gold series head pipe do you have?? gnarly, fatty, or sst?? this will determine if they will fit. sst silencers require sst headpipes i believe cause they have a different length mid pipe.
  18. did you ever get the bore size on the cylinders, and how much shipped to 64093?
  19. yes you can get half links, but not sure who sells them. Just go to DID.com or something. Not even sure if that is a website but its worth a shot. Also you could look at Rockymountainatv.com
  20. good to hear man, I too can never see me losing interest in my shee, but I have never had a crash like you. Hopefully you will change your mind after you get the thrill of riding it again!
  21. happy birthday man, I can't wait until my 21st, one more year.
  22. any engine or clutch components?? cylinders,clutch basket,gear between the kicker and basket,clutch hub. Thank that is it.
  23. Hey alright sounds good, we got some pretty cool bars here in downtown Warrensburg. Its called Pine Street, nothing but bars!! well and cops.
  24. yep me too, but I will never deal with him again, and i hope everyone reads this and doesn't deal with him either cause i think the only reason i got my stuff was because i talked to his wife, and she got my address and gave me the shipping info. So i don't know if he was trying to pull a fast one and his wife caught him or what but i am just happy it all worked out. I am not 100% happy yet now tomorrow when it is supposed to show up then i will be satisfied!
