badassbanshee479
Everything posted by badassbanshee479
  1. sounds lean! what compression are you running?? do you have the timing advanced at all? what type of fuel are you running? what oil and at what ratio?? did you happen to do a leak down test? may have an air leak
  2. how much for just the crank pistons cylinders and head?
  3. get the dremel out and mod your stocker! 1mm is equal to about 1 degree advance.
  4. my buddy runs a set of those on his dune port 350 and he blows them away with a 10 over arm. We are still playin with gearing though
  5. who set them up?? do you happen to know what needles are in them??
  6. you missed out on a good deal man
  7. you tryin to drill for the tors kit?? if you are its not that big of a deal! just go slow and makes sure you do not ram the drill into the other side of the carb when it breaks threw
  8. yep! no one has any damn money right now. I get a bunch of low ball offers, thats about it gear it till you can :biggrin:
  9. did you happen to check the squish when you put it together?? did you check the comp with a couple different gauges?? what is it doing that you think its jetting?
  10. 22-11-8 11 extreams :biggrin:
  11. not a problem man
  12. seams like it these days dont it
  13. I think I would bump the front up to a 15 tooth and leave the rear. Just remember, up in the front more top end, down in the front more acceleration, less top end In the rear, down in the rear more top end, and up in the rear, more acceleration. Also, adding 1 tooth to the front sprocket is like removing three from the rear, and vise versa
  14. what all is done to your bike? and what front sprocket are you running?
  15. jeff likes to keep it personal when stuff gets ordered from him. he is also a small shop so he would never be able keep up with an internet order site
  16. this post is over a year old. it sold sorry
  17. round house or stock style swinger?
  18. the cub domes are probably cut for the big bore, the oring groove will be moved to out more than the regular domes. Also, alky domes are cut different than regular domes.
  19. still have my 89 for 1300.00! http://www.bansheehq.com/forums/index.php?...c=83923&hl= pics on second page
  20. triple carcel get it right! :biggrin:
  21. fast cuts a nice trans! cant go wrong there
  22. I buy mine from the auto parts store. ngks are 1.50 each!
  23. not sure yet :biggrin:
  24. dont happen to need a 4mill cub do ya?? lets talk!
