badassbanshee479
Everything posted by badassbanshee479
  1. should you mix it at the recommended 1/2 oz. to one gallon mixture? or just run it at 32:1 like regular oil?
  2. dave.. you are not right!!
  3. pm sent jeff!
  4. have any bald 6 ply tires?? I am looking for something I can stud for the ice this year
  5. bump for a great seller!
  6. damn... and I thought I was jumping the gun :biggrin:
  7. did you disconnect the black box under the gas tank?? how about the clutch wire and the throttle wire?? is the e brake still on the bike?? did you check the reeds? 200 mains seems alittle small for a piped bike. what is your elevation?
  8. do you happen to remember where that was at?
  9. I will be there! there are a couple guys on here that will be there. there are a bunch of guys over on planet sand that will be there!
  10. I had really good luck with the 21-12-8 9 paddles on my play bike with about the same mods. the extreams have reinforced blades, they are not any taller than the regular haulers
  11. yeah I tape mine to the silencer core. helps when you are tryin to reinstall it too!
  12. bump! Some one needs an early Christmas present!
  13. you can only run the blaster pistons when you go to a big bore setup I believe
  14. I have run both techniplate and and benol before with no issues (Ran low on fuel at a test and tune so dave hooked me up with some of his) did not run any different or anything. Only reason I run the techniplate is because it works in cold weather!
  15. helps if ya use a good working unit for testing :biggrin: good to hear ya got it goin
  16. Only 116 more days till the dunes open!! whose in for a spring trip? (yes I am going through withdraws already) :biggrin:
  17. I use house insulation. seems to work good.
  18. we shall see when you get your new tires. :biggrin:
  19. anal rapping with sand lube!!
  20. if you still have this stuff after Christmas I will take it off your hands.
  21. I see this sold over on planet sand
  22. where is the best place to buy floats at??
  23. lack of lubrication! what oil and at what pre mix where you running? some oils will not stay mixed in cold weather!!
  24. Yep same bike :biggrin: He started out with jeffs dune port on race gas at the start of the season, he then rode my bike and instantly went out and bought a dunable override, converted to alky and tried to ride it on a 6 over arm. well after we got done laughing at him, he sold the brats and the swinger, then he went to a 10 over and 10 paddles. still running the same gearing that he was running on gas! he is hooked to say the least!
