I have a 1996 Yamaha Banshee. I put everything in a Lightened 89 J-Arm frame(needs Powdercoat). New 12.5" Marvin shaw shocks on the front and a R-1 shock in the rear, +6 swingarm and Stainless braided rear brake line, New chain and sprockets, Plastic is race cut and a stainless grill has been installed, custon seat cover installed, Skat-trak Mohawks on Douglas wheels, New 20X10X8 Skattrak 8 paddle Extremes on Douglas wheels, Aluminum Cascade Handle bars and new Pro design Teather switch, Set up with twist throttle. Wiring harness is as simple as it gets-3 wires. Cdi box is under the radiator in the front.
The motor was completely built by Dan Hull @ A&S Racing. The top end is off the motor and motor is out of bike(Fresh Bore and pistons By Dan also). Stage 3 plus port work, Cut head for race fuel, R-1 clutch kit and roller clutch bearings, Shift-star and shift drum mod, Crank is rebuilt, new crank bearings and trued and welded, All new seals, Billet timing plate, lightnened flywheel, V-Force 2 Reeds, Carbs are bored to 27.5mm, Also have a fresh set of A&S Alcohol carbs, New K+N filters. CPI inframe drag pipes/Sparkies.
Bike ran 5.13 in 300 ft with stock carbs
No trades and $2000.00 Firm
Bike is in Mid-Michigan
Call or email me HERE I don't get on here much anymore.
(989)701-0238
Rich
