badassbanshee479
Everything posted by badassbanshee479
  1. try running a ground from the cylinder to the chassis somewhere. make sure you get the chassis spot sanded up real good
  2. yeah
  3. I would start with a bushing kit. You cant replace the ball joints on the stock a arms or j arms. it is common for the j arms to eat bushings. Thats why people convert to a arms
  4. he was supposed to have them both for this year too though. :biggrin:
  5. is it the ball joints or the arm bushings?
  6. 22-11-8 8 paddles if you drag race at all, or a set of 20-10-10's 8paddles if you just like to screw around and have fun. I would not run wheel spacers, to much stress on the wheel studs. if you wanna make your bike wider, buy an axle and a set of 2+1 arms
  7. thanks! your not lien there! you would not think that all you cut out would add up to much. When I took mine to the powder coaters I took my friends also, when I loaded them both in the truck was when I really noticed the weight difference!
  8. did you bypass the key??
  9. brent has a 28 ft inclosed trailer we could take if ya want. then we would have something to set beds up in too! dave, even if you dont have a bike you should go! I have an extra on you can ride if ya want. I think jr is gonna buy my play bike and build a "little 350 that could"
  10. does not matter to me!! Pick one
  11. where abouts you live?? if close enough I could look at it for ya
  12. bump for a very clean and fast bike!!
  13. down to 107 days!!
  14. gotta be gettin closer, there are people ice fishin by me already!
  15. get your self alot of beer!! I am not gonna lie, it is a pain in the ass to cut it all out, grind it and make is look good!!
  16. glad to help!
  17. I had a guy over on planet sand build the sub frame out of 3/4 chrome alloy where abouts are you talkin for the brace??
  18. I run this at the dunes all the time. not to sure what kinda duning you are doing. dont think I would jump it, but thats just me
  19. I used to run turbo blue leaded race gas, it was 110 octane. My plugs used to be yellow after running them for a while
  20. sig also!
  21. http://www.bansheehq.com/index.php?option=...3&Itemid=28 try this, its the only way to really know where your jetting is!!
  22. leaded race gas will make plugs different colors
  23. is the flywheel rusty?? inside or out? clean the little pads on the out side of the fly wheel where the pick up reads to fire the motor! Do you have a ground going from the engine to the chassis?? is the frame painted or powder coated?? sand all the powder coast off of where the egine mounts go threw. ( I know it sounds dumb but I have seen it cause no fire!) Did you replace the cdi and stator with known good parts?? have you ohmed the stator with a meter?? un plug it and read the stripped wires first, then the soild wires. they should be within 100 ohms of one another. ( example, one set is at 17 ohms, other set of wires is at 117 ohms. give or take a few) if you bypassed the key, did you reconnect the wires to one another? seen that one a few times too! is the pick up on the stator set at .018-.020?? report back and we will go from there.
