kw04
Everything posted by kw04
  1. you don't have to shave the domes if you use a spacer plate.
  2. i should have brought a video camera it was a good front flip. you know you can put your clutch on the right side and try that then you might be able to ride a little. ill help you put it in and out of the truck.
  3. how about near fayetteville nc
  4. it is on the top of each carb
  5. probably around a 280 main jet. and adjust airscrews
  6. if you can start it with your hand i would think you need a topend.
  7. i usually wipe the frme down with wd40
  8. i like the smell of benoil just my .02
  9. well just put the 34mm pj's on and took it for a ride it seems to haul balls. but my question is about the plugs one is a little darker than the other but the base of the porcelin part on both seems to be a light brown. no spitting sputtering not acting up at all just want to know about the differance in plug colors is it safe .
  10. yea it will probably be a couple of weeks before i get to go up there. but i just found out another guy wants to race and he has a predator 500 troy lee edition. so when i do go i should be having a little bit of fun.
  11. yea i already had the tors eliminator on there then i just got a new thumb throttle assemble.
  12. if you put in a stroker crsnk you either have to use a spacer plate betwweb the jugs and the cases or have the domes milled out.. hope that helps.
  13. when i take leave and go back to massachuetts
  14. look at the people you are asking. i think most people would say banshee. but if you cant handle it get the beefed up warrior.
  15. what jetting are you running with what mods and whats your elevation.
  16. just making sure dont want to look like a dumb ass!!!
  17. good to hear its running good.
  18. i dont think it will work. i tried putting ex hubs on a raptor and it didnt work.
  19. if it only has reed spacers you might want some reeds.
  20. how are they on the top end??
  21. dont worry i do and if you want i'll send you a reciept for every last nut and bolt.
  22. vforce 2's and no complaints from me
  23. i think i had a 290 main stock pilot in mine with the fatties and filter. that was before i rebuilt ithope that helps a little.
  24. will a shee beat one of these things?? i have a buddy with a stock 700 who keeps talking trash. but before i race him i want to know if i stand a chance. mods include: 4mm stroker bored 20 over cool head 20cc domes ported timing +3deg vforce 2 34mm pj carbs 15/41 gears fatties his 700 is stock.
  25. i have a pair of stock carbs with the tors removel kit. they dont hve the cable because i had to use them on my new carbs.
