kw04
Everything posted by kw04
  1. ill try to get pics on her tonight or tommorrow.
  2. i have pretty much a complete 97 rolling chassis stripped down. missing one rear hub handle bars radiator and engine make a good offer and you can take it all. also no shocks. pm if your interrested.
  3. if you ride in alot of wet or muddy areas dont put the pods on you will want the air box just my .02
  4. when you go with a longer swingarm you need to have the shock rebuilt or by a new one to compensate for the added lenght. hope that helps.
  5. i had the same thing happen on my 04 come to find out i had to replace the shock or get it rebuilt because the seals where junk.. hope that helps.
  6. sprockets make it go alot faster. engine mods give it the power to turn the taller gears ratios to go faster. that helps.
  7. kw04
    Frame
    ive got a 97 frame
  8. tj you wanna go this weekend like tommorrow the 7th
  9. kw04
    Spindles.
    ok
  10. kw04
    Spindles.
    i have both spindles and a stock axle make me a desent offer and they are yours. came off a 97 shee.
  11. kw04
    banshee
    go to east coast atv you can trade yours for a chrome one and all you pay is the chroming.
  12. ive got rotors calipers both brake lines rubber and steel the leveler. and i also have the hole rear end brake setup plus a stock axle. oh yea spindle a-arms but you need to get the shoes for the calipers. make me a good offer and its yours.
  13. i found it at a local track sitting there and asked the guy how much. then he said just take it. and then it went into the truck and in the garage to be striped.
  14. just picked up a 97 shee with no engine or handle bars. and guess what i got it for? not a damn thing just take it.
  15. do you have after market carb tops on with idle screws? if you do it could be the idle screw was put in at a slight angle.
  16. vforce2 or 3 that should be good .
  17. when you cut the plug you cut it at the bottom of the threads so you can see the bottom of the porcilin part.
  18. hey where you at on bragg. what unit?
  19. instead of a degree key get an adjustable timing plate.
  20. yea just a little rich i think i need around a 310 main and i will be good but that will have to wait until monday. thn we will see how it goes.
  21. its now running pretty good but why do i get some oil out of the silencers???
  22. where you at man. i mean you at ft. bragg just asking cause of the name?
  23. its not a limited edtion anymore its a special edtion. just thought id throw that in if anyone cares.
  24. finally got it to idle.. the guy who put the idle srews in drill the hole at a slight angle. so i shaved the srew and bam we now have an idle. also put the 370 in and will have to wait until tommorrow to take it for a ride.
  25. i had it sitting right in front of me and still put the wrong thing stupid stupid.
