sheefreak
Everything posted by sheefreak
  1. Do you happen to know if they allow little ones to ride as well?
  2. Woohhhhoooo! That is less than an hour drive for me!!!!
  3. I will be there and a few other of the drag guys. Find us on the strip and someone will give you a hand. I don't have a carb sync tool, but can get you plenty close eyeballin it. If you are wanting to meet up before the dunes I will be there after 9:30 Thursday night.
  4. A lean condition is causing this. You are somehow lean on the needle or possibly the pilot ckt. Check your slides and sync. I have had my adjusters at the tops of the carbs come loose and cause this. Where is the clip at on the needles? Could be an air leak. Need to check all these things. And if it happens again, hold the brake and dump the clutch, it will shut her down.
  5. Thanks, but I only need the lockup. If for some reason you separate them I would take the lockup. Anyone else?
  6. Just as title says. Needs to be in good shape w/all parts/weights.
  7. Definately don't run it till you figure it out. As mentioned you will hydro lock it and break stuff.
  8. Good deal, I appreciate the offer. I will let you know.
  9. Are you shire it's water?
  10. If you are wanting to get it used up, I will buy mine from you Shayne Labor weekend. As far as where I am staying, it is still up in the air. The wife might come, and if that is the case I am going to try and find a last minute vacancy on a cabin. If she doesn't go, I will prolly stay w/a friend. Are you camping? I am going to try and get there Thursday night.
  11. Snomo setup of course....Kinda missed he mentioned mated to Banshee cases
  12. I wish :sad: Looks like Labor weekend for me. Is there a T&T at Bobs the following weekend?
  13. I think what you are doing is great.....I wish I had the ability, and access to tooling to do what you are attempting. I am interested in the outcome. Obviously you are not going to end up w/a 200 plus horse monster you would w/the billet cases and aftermarket cylinders, but I don't believe that is what you are after anyway...... Good luck w/it.
  14. There are a ton of tripple banshees out there, just not many like this one.
  15. I would put my 10mill cub against a 583 any day of the week...
  16. You mentioned A&S...did you buy this setup from Dan, or just the gaskets?
  17. Would you be interested in trading paint work for polishing work? Talking about a fiberglass front piece...
  18. I am assuming so.....but if not it will be fun to see him try and keep a chain on it.
  19. What you are saying is a little contrdictary. If you had a bad stator side crank seal, you are most likely going to fail a leakdown test. It is possible to be bad and pass a leakdown but is not likely. In this case it would fail a vaccum test. Also, you said the plugs look rich then they look white when it starts to act up??? Give us a rundown of your setup and jetting and we will hash this out.
  20. Buy one from Tim(AZCUSTOMQUADS), you will not be dissapointed. He is a great guy and builds a great product!!!!
  21. Sounds like you are pretty rich to me. What do your plugs look like. Did it all of a sudden start to happen, or happen after some changes..... Does it start well cold w/o the choke? If you have a bad crank seal on the right side, it will be spraying oil out the right side exhaust pretty bad.
  22. Must be an alky injected deisel judging by the 1350 psi injectors.....Can I ride it :biggrin:
  23. ????????+ 18.... 159 hp......what kinda 10 mill are we talking about?
  24. Do you have any drill bits small enough to fit in the power jet? You can then measure w/a mic. I don't know what range of jet sizes a powerjet can make up for, but it is a pretty good amount. You should be able to get pretty close measuring the PJ. Obviously you will not flow anymore than the barb for the PJ that the fuel line connects to so you might want to measure that as well to make sure it isn't smaller than the tube. It shouldn't be though....
