superchicken
Everything posted by superchicken
  1. how much for the roller? iv been pondering the idea of dragging next year. are you staying local?
  2. its been my experiance in car engines with chrome versus aluminum valve covers.the raw alm. dissipates heat better than chrome because of surface area.so yes there will be a gain in temps but may be acceptable.
  3. dipping one tooth on the front will cuase a gain in lower end,But will cause never ending shifting in tight to open trails.go up a size and it will widen gearing to less shifting and higher mph.i hope you get what im saying cuase i just woke up
  4. get some pipes on that thing.also why the split on gas,when its not needed
  5. so you say.ive whipped many a r's in the woods. I know it depends on the rider,bla blah,blah
  6. thays a good line i'll have to remember that one
  7. miss a couple of gears and you should still walk away.
  8. im down for it.it would be nice to meet up with someone whos firmiliar with the area though.only if meat was around.
  9. sounds like a legit deal.charles is a stand up guy,and for the noobie to still unhappy seems like somethings amist with him.just in plain engish,hes trying to get over on him
  10. tell me about it.herniated disk,left knee cap dosent track right,and torn miniscus,left rotary cuff is out of commission. life is good with a 120 pills a month for life.
  11. there his he fabbed them up
  12. you made the right choice.i run delta 2's on a ported 78 hp engine.like you said there tried and true.
  13. this is great,
  14. very nice! how much for a set?
  15. smaller on the back end gives you more on the top end.
  16. i hope you dont work on your banshee.ill leave this one to some one with patience.BTW welcome to the HQ
  17. stick with rockets you wont be sorry.order them now and by the time you have it together youll already have your pipes
  18. DID you get it to stop leaking oil through the cases?did you finally figure out the problem. i know it blew the crank soon after you got it in march.i hope the cases werent cracked
  19. patsy cline-i fall to peices george michaels- greatest hits various showtunes of the 80's thats what i listen to when i want to get funky
  20. how much for the tires ?are the rears the same size on both sides?
  21. the way i did my last top end was easy.put the rings on the right way,put in the inboard side c-clip in piston,insert the piston the correct way a little bit into the bottom of the bore,enough for the wrist pin hole to show.next put wrist pin in piston with a little 2 stroke oil.put c-clip in on out side, slide the jug the rest of the way down.repeat other side.just dont forget to put base gaskets on and rags above crank to save from a lost c-clip.before i put the head on i like to put a little 2-stroke oil in the clyinders and turn it over a few times to get the rings lubed
  22. that particular one i got from dennis kirk ebay sales.it was a scratch and dent type of sale.for 10 bucks ill live with some creases that i got out any way.but you can get them through dennis kirk or ceet mfg.
