superchicken
Everything posted by superchicken
  1. it sounds like a parking brake switch,not sure if a 97 has it or not.that switch wont let the rpms go past much more than idle.unplug the tors box under the left side of the gas tank and see if she wile fire up
  2. ive had a 450 see my grab bar more than once
  3. got one not to long ago had a problem with my coil,but after i got that stait im lovin my dyna.you deffinatly can feel a differance
  4. the only thing that i know a boost bottle does,is get in the way of the fucking fuel lines.
  5. i agree 7 degrees seems a little much.also you said you have some kind of grill,does it decrees the air flow to the radiator.i have a cool head,145 lbs. of compression and it runs at 160 to 180 degrees.and i feel the heat from the pipes
  6. well i finally have good news,it turned out to be the coil.for some strange reason it would run with the stock cdi,but not with the dyna fs.the stocker must be able to work with less resistance across the primarys,and the dyna must just grounds out.took it for a spin last night noticed alot more bottom end.cant really say it its all because of the dyna box or the complete new electrical system thats in her
  7. well thanx every one for replying,ive checked the wiring to the kill switch it was fine tors is disconected the only solid proof that something is wrong,is that the coil has no primary resisistance.so it seems to me the coils grounding out.got a new one comeing soon.does anyone know the best curve for 145lb.s of compression.dont want to get any dentonation.thanx scott
  8. ok got something to add.would a weak coil cause it not to want to idle with the dyna box?but run with the stock cdi.
  9. sadly to say yes it does run with the stock cdi box,yes i do have resistor plugs in it and the stock timing.i was on the timing issue,i thought the first go round with my problem was that it may have a degree key in it,wasnt able to check the timing lent my light to a buddy,but check it last night and it was right on the money.changed the stator back to my old one stll the same.and on the dyna tech help,the head tech scott told me that some times from the facorty there boxes get sent out with two wires in the wrong position,take them out of the connector,reposision them and it should run.NO help.im really fed up with this box 300$ dollars and its turning into a paperweight
  10. well ill try to make this short.bought a dyna fs box last month,got the wrong year so i bought a wiring harness to match.hooked it all up started and died,every time,with the ocasional back fire.ok,attributed it to the parking brake switch that my bike didnt have but the newer wiring harness did.played with the wiring still no luck got fed up,sent it back.meanwhile i hooked the original harness up with the stock cdi,fired up with a few kicks,so i know it wasnt the bike.now the fucked up part,i talked to a guy at dyna told him i bought the wrong year box and couldnt get it to run even with the correct harness.so they were nice enough to send me the correct year.i tought my worries were over.got the new box today,and still the same fucking thing,starts every time but only climbs up to like 2500 rpm and dies.every time.its driving me nuts.does anyone have an answer to my problem.thanks scott
  11. had the same problem.cdi was bad,made due by bangging on it,but got old real quick.got a dyna fs,reliable starts every time now
  12. id like to get in on this ride.hammonton is were i call home.id love to send them doofs of steel home.
  13. try regular rubbing alcohol,its a little easier on clear coats on cars and should loosen up the tag if it isnt really cured
  14. isnt there a channel called BET? something entertainment network.huh just wondering
  15. i was just up there this past saturday,and i was impressed with there business.very helpfull with questions,and good with there prices.it was like an indoor atv junkyard.maybe he was pissed off that the fact that he has two blasers that have a shit load of dust on them,and because he cant move their parts.
  16. man i really got this post out to left field,i love this shit.
  17. i know the one.my parants live down the road from there.if its true that there letting people ride in there,thats cool.there some good riding down there.might have to take a ride down there today and see.
  18. i would take into consideration the additional weight from the 50 over side as opposed to the 30 over side,might throw the balance off
  19. Sycotic produces a skeptical, non-believer style of thinking. People with strong sycotic miasms are very hard to convince, for example, that a new medicine or a different viewpoint may be beneficial for them or that their life will ever improve. They are often sullen, irritable, and fixed in their ideas. It also shares a manic-depression quality that is similarly found in the polio miasm. For instance, for a couple of days you may feel on top of the world and later, a deep depression may follow. The sycotic depression carries with it a tiredness bordering exhaustion. In fact, one Materia Medica refers to the sycotic condition as a "state of collapse". Other symptoms of the sycotic miasm include: Forgetfulness - Dullness - Talkativeness - Manipulative Suspicious (paranoid) - Anger - Fear of dark - Rebellious Panic attacks - Nausea - Headaches - Sore throats Runny nose - Canker sores in mouth - Nose bleeds Chronic diarrhea for more read here http://www.bodyved.com/Sycotic.htm thank you very much efwardo
  20. im a closet sycotic
  21. if your talking about the port down near leesburg,you might have to pay to get your bike out of the impound.the sand plant who owns it is cracking down on riders but i know plenty that still go.ive been going there since i was a wee kid with older brothers.alot has changed
  22. im trying to figure out were to start so here it is.my shee is a 97,but some on before me put a 96 ignition and i didnt know it.so when i ordered my dyna box i bought a 97.got the box whent to install it didnt work.ok istead of cuting the dyna up i got a 97 and newer wirng harness.ok,put the new harness on,and at the same time put a ricky stator on.on the wiring harness didnt hook up any of the tors system,but i did connect the red and black key switch wires together,cause i dont have a key switch that works.got every thing together and it fires up with almost a half a kick but only runs for for a few seconds.every time i kick it over it sounds the exact same way.almost like the ignitions getting shut down at the same rpm.the bike ran like a champ before all of this.the only thing i can come up with is the parking brake switch,and the key switch.in the wiring diagram for a 96 it has the key switch to be a closed circut to run and for a 2001 it has it open to run?/?im stuck with this.sorry for the novel just trying to decribe my pain the best i can
  23. theres alot of little pits near ya.one that comes to mind is the one near penco tech.and a few around me.stop in over service specialtys in clayton,ken might be able to help you out with your problem,and tell you about some places to ride near you that are cop safe
  24. hey nasty sounds like you live in my neck of the woods.im in hammonton. were r you at?
