2004LEBanshee
Everything posted by 2004LEBanshee
  1. Cheaper to rebuild and revalve a stocker. If done right its a pretty good shock. Up to your riding to determine if you really need a custom aftermarket. A custom set up elka for example would be better performance wise. Most people will not need it though imo.
  2. Mine was cracked from factory. Get a billet one
  3. Yes they can but they must remain a specific length. I dont remember what it is. I think their site might say.
  4. No it spins but some times its tight in certain areas and it seems to bend easy. I think I screwed the tool up when I first used it. A combo of new powder coating and nuts not loose enough caused me to bend it. I bend it back but it think its just weaker now. It moves a inch or so easy in both directions then gets tough. Probably dirt.
  5. I have a pin style tool that came with my carrier. My issue is it some times bends. Does anyone sell a better tool to make adjustment easier. Yes I loosen the dam bolts. Thanks
  6. Yea when its bad it will bounce you off this dam seat through bumps.
  7. My fast ported 421 serval ran with a plus 4. It never got enough traction to come up with dirt tires. At the drags with 10 paddles it would come up with ne on the bars and lined up in the ditches. I weigh 218 also. I'm sure I could have trailed it at plus 2.
  8. Zillafreak that wouldn't be wellsville would it?
  9. Prodesign style fins and stock shaft. Best setup
  10. Mattoon. Heavy ass plate. Stiff bushings and big ass screws. G/l.
  11. Its amazing how many of the oem parts are better then the aftermarket with these thing. Electrical being a big one.
  12. Stator can test good and still be bad. I'd swap it and a coil for a known good one.
  13. What stater you running. I'm betting ricky statorish. Swap it for a stocker and see.
  14. Hook it to a truck and pull start it. You can usually break em free. I bet its not that bad. G/l
  15. Should have no prob staying around 3500 for a 4cub or serval. Do it right talk to a good builder and buy from them. They will usually give you a little deal on stuff if you buy enough. Imo
  16. Yea they should all be moved.
  17. I have a set of pwk 35s with 2 sets of filters and 1 set of outerwears on ebay right know. Also have a set of upp intakes with out the crossover for sale as well. Let me know. Sale ends sun. We can work something out and ill stop the sale.
  18. I vote 10 DM. You already have cases trenched for a 10 and you may have a good billet crank for the 10 as well.
  19. You could get the eibach spring cascade sells. Its for a plus 4 with no valving. I bet its close.
  20. Sure it will. In the back of a truck.
  21. Sent offer for the intakes. Didn't notice if they were sold.
  22. http://youngstown.craigslist.org/sno/4004244421.html This ones a gem only 2600. Says the rears only have been used 2x since new.
  23. Just use a smaller ball bearing then. Stock size.
