Oilsmoke
Everything posted by Oilsmoke
  1. DUNEDEMON I am running 5 inch over swing arm. I am old man so my thinking is stock valuing is ok for my riding style but the spring is to soft for the added length. My preload is all but maxed out also. Do I need a different spring rate and with a progressive wind? What would the cost be ballpark? Some insight would be great.
  2. Fusion works best without primer. It's etch into the plastic with the chemicals in the paint That's why it's called FUSION plastic paint. Just look at my shee. No primer Just 4 coats of Black Fusion. Clean it and paint. It flex pretty good I think for a 12 dollar paint job.
  3. Thx Guys for the compliments. Clamps where off ebay, Some guys makes aluminum covers and use is Hi-temp silicone hose. I think he was called SS-King I like these clamp very light but work great.
  4. I don't see many foam filters at the dune. K&N's with prefilter or outwears.
  5. OK hear is my New ProFLow 35.2mm bored Mikunis and Velocity tube setup, with K&N Model RU-1720 filters This clears the shearer Pipes Great. I split the space top and bottom and than Made a Brace to keep them wobble free.Very Solid and I should get any rub damage Tubes are 2.25 inch dia. by 3.5 long. Jim that long enough? Filters are 20 degree angle with 2.25 inlet 3.5 x 6 inch body Just what the Passion 4mill long rod 12 port stroker Needs to breath Easy. intake pic 1 intake pic 2 I tired the img link and got this error:Sorry, dynamic pages in the tags are not allowed. What happened?
  6. Where is an elphants Sex organs at? They
  7. Oilsmoke
    Toe In
    Thx Guys I set it at about 1/4 inch square them up with bars straight and used a long straight edge to center on the rear wheel than set the toe in seammed to work great.
  8. Well than take the silencer off and if the sparks are still there than you better pull the head and See. If it stops than you can clean and repack your silencer. But I know I would not sleep at night wondering about engine failure.
  9. I like to use the Mirco fish at www.bikebandit.com for stock parts. If i remeber right that gear does have some play ( wobble side to side) it doesn't play a major in the engines normal opertion, so some play should be ok. Did you lose the c clip that holds it on. was it in the botton of the clutch cover. if so replace it with a new one. It came off for a reason.
  10. What is the Difference between a Women and a Battery? The battery has a Postive side.
  11. Tommey would never change the desgin because of the Hush kits. Some Dick weeds scam is my quess.
  12. www.ajusa.com i just bought some from www.ajusa.com cost was 26.08 for model ru-1720. this was 20 degree angle 2.25 inlet with a 3.5 by 6 inch body. precharger was model ru-0520 , cost was 12.11 shipping was free for a total of 76.38
  13. Here is a pic of a modifed stock timing Plate I had machined by my friend at work. It's cut 4.5mm deeper on the counterclockwise side for about 4.5 degree. Does your plate look like this one. If so you can demel it by hand to get more timing out of them stocker.
  14. Oilsmoke
    Toe In
    Looking for some info on this spec. How much is needed. shee need to be weighted or tires off the ground? make a differnce if it's a Duner,drag or mx riding styles.Does swing arm length change anything? How do you measure it.
  15. Reas11 Ported his Shee with T6's Then Sold them for a Set of Shearer. You could pm him and ask him his View on Porting with t6's.
  16. Your Plan on fuel or octane levels? Target PSI ?
  17. I would call Matt at Shearer and or email them ask the what size oring dia to use. I have K&S gasket set and My shear when right on. Maybe the FMF are little bigger dia.
  18. Put alittle oil on the oring and push it on Don't be a wimp
  19. Noss Customer Service is Bar none the Best there IS. His head is good too. lol Why dosen't that Sound right? What is your alt tijoe696?
  20. Thx Tommey, It's Not a Show shee but It's Nice Duner workhorse. After your paint cures real good. To Clean it, an Old trick is Lemon pledge furniture polish, Paint & seat will looks great,It cleans off easyer after you get it dirty too. Also good & Cheap.
  21. I bought my Son Sandstar and I have Mohawks and they weight about the Same. Other Son stole my smoothies So if Turning is important to you The sand stars are the Best and they Look Cool to. Keep them. Smoothies Suck But they are Lite as Hell
  22. Thats No shit And the Lava Rocks can be a Bitch also.
