Aaight fellas. Some of you know that I run a much larger main than I should, for those that don't know. I have a single 35mm/Trinity manifold setup. I run a 230 main, where the typical jetting for my mods are around 180. I can't even get a richer jet than a 230, so that's how rich that is. My plugs don't look all that bad, it runs pretty good, but I SHOULD NOT be running a 230 main.
Now, I ordered all new gaskets from Trinity for my manifold and reed assembly. Tonight, I took my intake assembly apart, took the reeds apart, took off the airbox, just plain disassembled the whole intake for inspection of the gaskets and reeds and everything.
Honestly, I couldn't remember if my manifold was the old o-ring style or the new gasket style, and was half hoping to have the oring so I could have an easy fix with the new gaskets. Nope!! All my reeds look good, all the gaskets looked pretty good, and the rubber piece that mounts the carb to the manifold also looks good. So, I have NO IDEA where my leak is coming from. I don't even really know that I have a leak.
At idle, I've checked for leaks with propane gas, carb cleaner, and any other thing I could use and can't find a DAMN thing!! I had figured that my leak would occur at higher rpms under a load where the engine is sucking a little harder, but I've never actually located the leak. I still have everything apart, cleaned and more or less readly to put back in, but I really hate to without having found something suspicious. I've been riding like this for 6 months with no ill effect, but this just ain't right.
Anyone have any ideas. Also, I took a pic of the intake tract, and there's a lot of black speckles, they don't flake off on my fingers unless I really rub on them or use my nail. Don't know if it's normal or not.
Later.
