MILO Posted March 2, 2009 Report Posted March 2, 2009 (edited) 1) What type of aftermarket exhaust do you have? pro circuit 2) What type of airfilter do you have? pro design foam 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all b 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 1250 5) What size pilot jets are you using? stock 6) What size main jets are you using? 370 7) What temperature is your Banshee jetted for? 70-90 8) Do you have a port job? not yet 9) What kind of carbs? stock 10) What size carbs? stock Edited March 2, 2009 by MILO Quote
Aitchy Posted March 10, 2009 Report Posted March 10, 2009 Please copy and paste this along with your answers in your reply, thanks. 1) What type of aftermarket exhaust do you have? FMF Gold series , Power core 2 Silencers 2) What type of airfilter do you have ?, Pod Filter 3) Running stock airbox with NO lid + Outerwears pre filter lid 4) What is your elevation? I ride between Sea level -> 1000 ft 5) What size pilot jets are you using? 48 6) What size main jets are you using? 150 7) What temperature is your Banshee jetted for? 8) Do you have a port job? Dune porting 9) What kind of carbs? keihin D Sliders 10) What size carbs? 30mm Quote
screamin_banshee_2003 Posted March 10, 2009 Report Posted March 10, 2009 pipe used is shearer small bore inframe K&N pod filters Not running air box at all Elevation is 500ft Pilot jets used are 55 Main jets used are 158 Jetted for a temp of 75 Dune ported Using PWK 35mm carbs Quote
elwilliams13 Posted March 12, 2009 Report Posted March 12, 2009 (edited) 1) What type of aftermarket exhaust do you have? PT Mids 2) What type of airfilter do you have?K&N w/ proflow 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all B 4) What is your elevation? (If you don't know, go here: http://www.topozone.com )32ft ASL 5) What size pilot jets are you using?27.5 6) What size main jets are you using?300 7) What temperature is your Banshee jetted for?70-95 degrees F 8) Do you have a port job? aggresive trail 9) What kind of carbs?stockers 10) What size carbs?26mm Edited March 12, 2009 by elwilliams13 Quote
badbrad Posted March 13, 2009 Report Posted March 13, 2009 1) What type of aftermarket exhaust do you have?t5 2) What type of airfilter do you have?toomey 2 to 1 3) Are you d) no airbox at all 4) What is your elevation? 1200 5) What size pilot jets are you using?stock 1.5 turns i think 6) What size main jets are you using? 280 7) What temperature is your Banshee jetted for?50 - 10000 8) Do you have a port job?no 9) What kind of carbs?stock 10) What size carbs?stock exciting bike eh? Quote
badshee1998 Posted March 20, 2009 Report Posted March 20, 2009 ) What type of aftermarket exhaust do you have? toomey t-5s 2) What type of airfilter do you have? no air box, with kandn pods 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all no airbox at all 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) kansas, around 800-1000 5) What size pilot jets are you using? 27.5 6) What size main jets are you using? 340 7) What temperature is your Banshee jetted for? 70 8) Do you have a port job? F.A.S.T port job 9) What kind of carbs? mikunis 10) What size carbs? stock Thanks! Quote
m barrett Posted March 26, 2009 Report Posted March 26, 2009 ) What type of aftermarket exhaust do you have? toomey t-5s 2) What type of airfilter do you have? uni 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all C 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) SEALEVEL 5) What size pilot jets are you using? stock 6) What size main jets are you using? TOOMEY JET KIT WITH 280 MAINS 7) What temperature is your Banshee jetted for? it runs the best at 40 8) Do you have a port job? no 9) What kind of carbs? STOCK 10) What size carbs? stock Thanks! Quote
regalrocket Posted April 27, 2009 Report Posted April 27, 2009 This needs a sticky. I use this post more than anything, and it eliminates alot of the repeating questions about routine jetting combos. Quote
Handyman Posted April 27, 2009 Report Posted April 27, 2009 I have 2 banshee's so I'll do each one..... Note: the jetting in my sig sig is for 200ft above sea level...what I post id for my other riding spot at 4500ft above sea level.... 2005 421cc 4 mil Cheetah powervalve: 1) What type of aftermarket exhaust do you have? CPI inframe SB 2) What type of airfilter do you have? K&N filter pods 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all? No airbox 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 4500 5) What size pilot jets are you using? 48 6) What size main jets are you using?155 7) What temperature is your Banshee jetted for? mild weather 8) Do you have a port job? No 9) What kind of carbs? Keihn 10) What size carbs? 35 for my '99 1) What type of aftermarket exhaust do you have? Pro Circuit Platinum with T304 silencers 2) What type of airfilter do you have? K&N Filter pods 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all? No airbox 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 4500 5) What size pilot jets are you using? 27.5 6) What size main jets are you using? 340 7) What temperature is your Banshee jetted for? mild weather 8) Do you have a port job? no 9) What kind of carbs? Stock 10) What size carbs? 26(OEM) Quote
motodrumer58 Posted April 27, 2009 Report Posted April 27, 2009 (edited) 1) What type of aftermarket exhaust do you have? Pulse chargers 2) What type of airfilter do you have ?, Pod Filter 3) Running stock airbox with NO lid + Outerwears pre filter no lid 4) What is your elevation? I ride between Sea level -> 1000 ft 5) What size pilot jets are you using? 32.5 6) What size main jets are you using? 260 7) What temperature is your Banshee jetted for? 60-80 8) Do you have a port job? trail blazer by Rocky Baumler 9) What kind of carbs? stock 10) What size carbs? stock Edited April 27, 2009 by motodrumer58 Quote
fastrthnu Posted April 27, 2009 Report Posted April 27, 2009 1) What type of aftermarket exhaust do you have? Rockets 2) What type of airfilter do you have? k&n pods/outers 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all (d) 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) about 30' 5) What size pilot jets are you using? mikuni 30 6) What size main jets are you using? mikuni 410 7) What temperature is your Banshee jetted for? 80 +/- 8) Do you have a port job? Passion racing 12 port MX for +4mm 9) What kind of carbs? mikuni tm flatslide 10) What size carbs? 34mm Quote
petie11o5 Posted April 27, 2009 Report Posted April 27, 2009 1) What type of aftermarket exhaust do you have? FMF Gnarly w/ Powercore 2 Silencer 2) What type of airfilter do you have? K&N with Outerwear. 3) Are you running: stock airbox with NO lid 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 800-900 Feet. 5) What size pilot jets are you using? 32.5 6) What size main jets are you using? 310 7) What temperature is your Banshee jetted for? 80 8) Do you have a port job? Trinity Pro TT Port 9) What kind of carbs? Stock 10) What size carbs? Stock Side Note: Running a little rich. Quote
AustinTX Posted April 29, 2009 Report Posted April 29, 2009 1) What type of aftermarket exhaust do you have? CPI's 2) What type of airfilter do you have? K&N pods 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all none 4) What is your elevation? 600' 5) What size pilot jets are you using? 38's 6) What size main jets are you using? 165's 7) What temperature is your Banshee jetted for? 80-90 8) Do you have a port job? HJR dune port 9) What kind of carbs? Pwk's 10) What size carbs? 33's 11) CEL needles, clip in the middle Quote
tundish2800 Posted April 29, 2009 Report Posted April 29, 2009 1) What type of aftermarket exhaust do you have? CPI inframes 2) What type of airfilter do you have? K&N pods 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all no air box 4) What is your elevation? 600' 5) What size pilot jets are you using? 58 6) What size main jets are you using? 158 7) What temperature is your Banshee jetted for? 50-75 8) Do you have a port job? Flo Tek aggressive dune port 9) What kind of carbs? Keihins p.j. 10) What size carbs? 34mm 11)cgl needle 4th slot from the top Quote
