Everything posted by badbrad
as topic says. 250.00 shipped in us. thanks
price reduced to $2800
http://pennstate.craigslist.org/mcy/1341884094.html For Sale: 2004 Limited edition Banshee. Low hours. Second owner with title. List of mods: Toomey t-5 exhaust with 2 into 1 filter set-up (stock box included) +4 advanced timing plate Boysean reeds TORS removed Works A-T steeler front shocks Renthal bars Maxxis rzr II's all the way around (have ITP holeshot spares) Nerfs Case saver other misc items as well 120lbs of compression in each cylinder. Only selling cause I want to get bikes for my kids. Asking 3000 neg. Bike is usually clean. Sorry only pics I have at the moment.
anyone have any of this for a good deal? i just wrecked haha
Okay, so ever since riding my friends ltr450 I have been wanting to try 18's on the banshee, anyone else have pros and cons on them. I ride trails and only thing im worried about is that they are 2 ply and the loss of some clearance, but I have a feeling it will rip a little quicker opinions...
to me that just sounds like the echo of the airbox lid not on... sounds fine to me, maybe, if it responds poorly lean your airscrews out, but if you put your lid back on ill bet you dont hear that deep blurp plus, depending on your elevation and mods I would guess that your pilots may be too big, but Im not a banshee expert just trying to help cause Ive been there.
no idea what the hell factory uses, but i first bought some klotz lube and its gummy and not so good. my bro bought some maxima lube and I think its the best Ive used yet. It dont gum up but keeps a nice lubricant on the chain
wow, my power just went out! So... I put Sta-bil in my almost empty tank and it woke right up. Man I had an awesome explanation before the f'ing power went out. anyway cant remember where i was now.... turns out it was shitty gas. and on a side note, if you live in shitty little town with one gas station like me, take the time to maybe drive the extra miles to get good/reliable gas.. thanks though guys for all the input... I dont have a lot of time to work on my bike, let alone ride it.
Ok, so thanks for the input, but Im pretty sure it was bad gas. Now here is my explanation: when I went riding (the same day I noticed how shitty it was running) mind you, it was extremely humid out, I just discarded the problems due to that and wetness. t
brand new reeds installed correctly, carbs are clean as a whistle (i know dirt could still be in there), no leaking antifreeze. no idea what you mean with the piston, but I would think it would affect performance everywhere if it was a piston problem?
I am using an outerwear, but I just cleaned it well, and it was only on its 2nd use. Also, it ran fine with the old one before, the filter is completely clean and it still did it when I ran with no filter at all.
that is my next thing im going to check. its 93 mixed properly, but i guess there is rumors going around town about our station having shitty gas. say for example i paid for 93 but got 87, would this cause my problem? I am really hoping this is it. It dont seem like it could be anything else. I mean, i would be floored if there was dirt in my carbs because I keep it real clean and sealed up good too.
the mains are 280 and they have always been fine in the hotter weather. yes it revs and the tors is removed. i just switched plugs and no change....
this weekend I took the bike out. and it was very humid out, so I thought that and a minimally dirty air filter were my problem. I lost to a lt450r in drags and I knew something was up (mainly cause I always stomped him). well, I just discarded it all and blamed it on the humidity. now, two days later i get it out, clean it, clean the air filter, tighten the chain, etc. and take it for a spin. When I get on the gas its weak as hell. The top end acts like it has a rev limiter on it. It falls flat on its face basically through the whole rev though. The bottom and idle feel really boggy and un responsive. Now heres the specs 2004 on the stock bore and pistons (which im hoping you guys will say it prob needs rings) 2 into 1 toomey filter, t5's, +4 timing and thats it. Im a weekend rider and dont even go every weekend. Had the bike for almost 3 years. .. 2nd owner. anyone with any ideas?
Bike bogs down when it leans to the side
badbrad replied to badbrad's topic in General Banshee Discussion
all the screws are exactly the same. I am pretty sure it is rubber tipped. Plugs look totally fine and I didnt replace anything in it. Even when its idling and I tilt it to the side it starts to bog down really bad and sometimes almost stalls. then it goes back to normal after a throttle blurp or waiting like 6 seconds. Im to the point where I think something is going bad with the float valve -
Its a cr125 2002. I just re-ringed it, put new boysean reeds in it and cleaned the carb well. Put it back together and it bogs if you lean it half way to the ground. Then I took the carb off and I adjusted the float level (I think I did it right). But it still does it. I cleaned the shit out of the carb several times now with carb cleaner and lots of high pressure air. Im gonna go freaking crazy if I cant get this figured out soon. Any help is appreciated
Would Warrior fenders fit on banshee?
badbrad replied to xXBANSHEE_KILLAXx's topic in Banshee Appearance
even putting warrior grips on your banshee would make it suck worse than anything i can think of. fuck warriors, and no fenders at all would be better than warrior fenders. lol im kidding but really not. i just think warriors blow so hard that it makes me mad. i'd rather ride a blaster with no brakes or a fucking kawi bayou with one fucking gear.... just hate them hope my ranting helps!!!! -
that thing looks retarded i like the green hub
ok i got it off and i want to clean it up. there is a small, not very deep gouge at the top of the exhaust port. i got some ultra fine scotch brite pads. will this work as long as i dont do it too rough and follow the lines inside. also, what do you guys use to clean your juggs? do you soak them in anything or what? Im having a rough time getting the grime out and off. any help is greatly appreciated.
Of course i thought of that but i couldnt find my fucking mallot anywhere. So do you think I can smash it pretty good because i about pulled my nuts trying to pull on it. I mean its on there.
Okay, so im replacing the ring on a 125 cr 2002 and I for the life of me cannot get the f'ing jugg off. the back left stud seems to be hung up, maybe on the dowel pin or whatever its called. Is there a good way to attempt to get this thing off? I know I cant pound on it (hard) or pry it. anyone run into this. The head came off easily. btw, this is the first time its ever been apart.
Looking to buy this. The guy says he has only put a 1/2 tank of gas through it since the rebuild. He said the jugg is bore .065 over. Is that too much for the price and the reliability? Any help on this would really help me out. Thanks http://classifieds.pennswoods.net/classifi...?adindex=377439
Thinking about selling the banshee
badbrad replied to pinned247's topic in General Banshee Discussion
I AGREE WITH THIS ONE! about trails and shifting... sorry for the wrong above post -
Man I agree with this soooo much. damn it wrong quote -
I have unreal tourney 3 id be willing to trade also, oblivion madden 07 im interested in assasins creed
