Everything posted by screamin_banshee_2003
looks more agressive great banshee
boss billet intake problem
screamin_banshee_2003 replied to slopoke's topic in Banshee Repairs and Mods
great post and good information. i bet mine is leaking like shit why is that they are shiit while everybody is recommending them. When I did a search to buy one it was like if you didn't get a boss intake you are insane. if they are shiit then people should have start saying. -
glad to hear that it worked out i have a boss intake with built in crossover and i would like to know where did you add the rtv sealent. between the two pieces of the boss intake itself. or between the reed and the boss intake. thanx -
hey there guyz, i am not postin alot here but i am always around. i have bought a very clean used shearer pipes about 6 months ago. the right side pipe started to crack around the hanger about two months and it is gettin bigger. i just gave her a new top end with blaster 573 wiseco pistons(66.25) new cut doomes and a new clutch.(i had ripped both seals so the engine was burning trans. oil, and since it was opened i had to have a new top end for the new season) right now i am in the break in process what i am facing right now is that the right cracked pipe is a bit hotter (not that much as a sparkplug fail) than the left. if i keep the banshee idling it would get hot and the coolant container under the seat would bubble. another thing i noticed is that the exhasut pressure coming out from the right silencer is a bit powerful than the left side. even though i adjusted the left carb cutaway a bit higher than the right. and also i noticed that the right silencer is filled with oil residue while the left is dry. right now the crack is big enough to blow out a very small amount of exhaust depending on the throttle. can anybody tell me what am i facing? is a seal? is it the right pipe crack leaning out the right cylinder? or somethin else???? i am not smilling any burned transmission oil or coolant. i have cleaned the carb twice to make sure and it didn't work out. my mods are below in addition of pwk 35 carbs, shearer and wiseco blaster pistons. mix ratio at 24:1 with yamalube oil. I am running 162 mains and 52 pilots with air screw 4 turns out. altitude at sea level and temperature at 33-42 celsuis (probably around 90-105 F) the shee is running hard right now and i can bring the front up on fourth gear on pavment and there is no use of the first three gears. i love the shearer and how the power kicks in just like a turbo. any help would be appreciated. :cool:
RIPPEN (JAMEY) IS NOT DOIN GOOD
screamin_banshee_2003 replied to FASTOYS's topic in General Banshee Discussion
good to here that you are doing better, best of luck on gettin out the hospital and back to Hq :biggrin: -
WENT AHEAD AND MADE THE TRADE
screamin_banshee_2003 replied to figure8racer7463's topic in General Banshee Discussion
welcome 2 the banshe world. You didn't go wrong with the trade -
i am f..... Confused here Do u guyz really mean that fast and herr jugs shees can't run waith a&s shees (if the only changing variable is porting)
who calls their banshee a "shee?"
screamin_banshee_2003 replied to locogato11283's topic in General Banshee Discussion
gay. I dunno whats gay about it eventhough i call it the banshee and didnt pick the word shee except here. When i type i would write shee but while talkin i'll call it banshee. What i find fukin gay is the world lol. Do u guyz when u read a post pronounce it as a word or say the abv. Becayse when it is pronounced as a word it feels fukin gay. -
hi guyz I am facing problems with my cooling system. I think the piston either in the up or down stroke is pressurizing the cooling system. I changed the o-rings(cool head gaskets) with two diffrent mechanics and it didn't work out. Installed a used trinity stage 4 head and that didn't work also. Basicly my problem is that coolant is getting pumped out from the overflow tube beside the radiator. My shee would remove all the coolant in the coolant system in 5 minutes. Water is just getting pumped out of the overflow tube. The more i rev it the more the amount of water geting pumped. Is there other gasket other than the orings that could be worn and causing the problem. Could it be the rad cap Or maybe there is a hole in my transfers in which air fuel mix is getting inside the water jackets. Any theories or solution would be appreciated. I would clarify anythin that is not clear. I just want to ride the shee Thanx in advance
Clutch hard to pull in, need help
screamin_banshee_2003 replied to petenorth's topic in Banshee Repairs and Mods
if the clutch pull hard then probably a heavy duty springs are equiped in ur shee. If u want it to pull smoother then buy an easy pull lever with perch from fast (a sponsor of the hq) And lube your the clutch cable or even change it If your shee is jumpin forward when put in gear then you should adjust the arm where the clutch cable is hooked under the left carb. It should align with the arrow on the crank case. Look if there is a sag on the clutch lever you may get away without adjustin the arm What are your mods. -
shee acting wierd
screamin_banshee_2003 replied to sa3ood_banshee's topic in Banshee Repairs and Mods
hala wa'3ala Pull the choke on the carb and try it at wide oped throttle at all gears and if it was better then you are lean. If u just had only pipes and pods u would be way rich. Try using 290 or 300 main jet And also return the needle to the normal position no need to play with it 7abtain -
HELP with jetting PLEASE PLEASE PLEASE
screamin_banshee_2003 replied to mesa banshee's topic in Jetting & Exhaust Forum
for the main thats way high I was running 350 jets witha 4mil ported eng on the stock carbs If u are running the pods filter that hook up to the carb u should be around 300-320 Just removed the cover of the airbox I would say 290 or 300 The elevation and temp also plays a roll in jetting For temp. When it is cold u go up a size on the main jet ... Warmer down a size Goin 2 higher elev. Drop a size.. Goin to lower elev go up one size If it is hard 2 start change your ngk plugs. Ibet they are blacked out and soaked with the fuel mixture -
banshee still overheating
screamin_banshee_2003 replied to killshee's topic in Banshee Repairs and Mods
hmmm Did u ever disconnected the hoses from the overflow coolant container under the seat. There are two black hoses one is connected up and the other down. U may switched them while re installing. I did that once. U would loose coolant if that was the issue. -
to all banshee owners
screamin_banshee_2003 replied to TJScott's topic in General Banshee Discussion
it will over heat if u drive it hard or jet it towards lean. U would here the coolant under the seat and in the radiator fuzzing. I felt the diffrence when changing from a stock 2 a cool head -
they look similar to oof cpi i think Shearer are much smoother Those look bulky just like cpi
banshee hqers occupations?
screamin_banshee_2003 replied to lastnline75's topic in General Banshee Discussion
i am studyin at a uni Still freshman year Took chemical eng for a major Hope 4 the best -
This bike is SICK
screamin_banshee_2003 replied to trueraiderfan's topic in General Banshee Discussion
killer bike Hand it over 2 me and i bet it would look shitty diffrent after a half season -
wholy shit.. A girl missed up the bhq. But fukin nice, love the drama
best replacement clutch plates?
screamin_banshee_2003 replied to hollisatp's topic in Product Reviews
go fast and u wont be wrong I have ordered them internationally but they still didnt arrive I know that i wont be dissapointed with the fast clutch If u are low on cash u can get the stock one with 3 toomey hd clutch springs and it will hold up good with your mods. -
nice setup and i like the look of t6. Nice and smooth Make sure to jet it right. U should be between 280-310 When i had mine i just installed them and i jet it lean. Both pipes have turned to a gold color and blued out where the pipe fits the cylinder. Jet it right to keep them look nice
ok guys post your top 5
screamin_banshee_2003 replied to lokisbuddy's topic in General Banshee Discussion
shit i have a 4mil with a drag port on a stock swing arm. I wish i have a +6 swing arm And Some douglas 8'' with extreme 10 paddles. And yfz front conversion kit. Amen
