What jets are you using? Fill out this form...
1) What type of aftermarket exhaust do you have? Pro Circuits
2) What type of airfilter do you have? K&N
3) Air Filter set: Running open pod filters with outerwears.
4) What is your elevation? Sea Level
5) What size pilot jets are you using? 27.5
6) What size main jets are you using? 370-380 depending on outside temperature.
7) What temperature is your Banshee jetted for? 380 for 60 degrees and below, 370 in Summertime.
8) Do you have a port job? Yes
9) What kind of carbs? Mikuni TM's (flat slide)
10) What size carbs? 28mm
11) Needles? N68A needles in center clip position.
2.5 Slide cutout on these carbs for a banshee.
  • 2 weeks later...
1) What type of aftermarket exhaust do you have? Toomey T5s
2) What type of airfilter do you have? Unifilter with outerwear
3) Air Filter set: Pod filters
4) What is your elevation? 750'
5) What size pilot jets are you using? Keihin 50
6) What size main jets are you using? Keihin 152
7) What temperature is your Banshee jetted for? 70-90 degrees
8) Do you have a port job? No
9) What kind of carbs? OKO
10) What size carbs? 30mm
11) Needles? Center
  • 2 weeks later...
Please copy and paste this along with your answers in your reply, thanks.
1) What type of aftermarket exhaust do you have?cpi
2) What type of airfilter do you have?k&n 2 single flters
3) Are you a)running a stock airbox with lid B) stock airbox with NO lid c) Stock airbox with vents d) no airbox at all
4) What is your elevation? (If you don't know, go here: http://www.topozone.com )320metres 1049.9ft
5) What size pilot jets are you using?30
6) What size main jets are you using?320
Thanks!
8) Do you have a port job?milled head
9) What kind of carbs?mikuni
10) What size carbs?stock mikuni
Thanks!
  • 4 weeks later...
1) What type of aftermarket exhaust do you have?T5's
2) What type of airfilter do you have?K&N filter pods
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at allD no airbox at all
4) What is your elevation? (If you don't know, go here: http://www.topozone.com )sealevel
5) What size pilot jets are you using?48
6) What size main jets are you using?158
7) What temperature is your Banshee jetted for?70-90 degrees
8) Do you have a port job?HJR dune/play port
9) What kind of carbs?Keihin PJ's
10) What size carbs?34mm
11) How many turns out? .5
  • 2 months later...
1) What type of aftermarket exhaust do you have? Shearer SB inframes
2) What type of airfilter do you have? K & N pods
3) Are you a)running a stock airbox with lid B) stock airbox with NO lid c) Stock airbox with vents d) no airbox at all None
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 1800
5) What size pilot jets are you using? 50-- CEL middle clip
6) What size main jets are you using? 152
7) What temperature is your Banshee jetted for? 60- 70
8) Do you have a port job? HJR
9) What kind of carbs? PWK
10) What size carbs? 35
Edited by shee4speed
stock air box no lid
995 feets
stock 25
290 with the stock needle in the 4th clip
290 on summer 300=310 on winter
nope
stock
stock
1) What type of aftermarket exhaust do you have? t5s
2) What type of airfilter do you have?3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all 1 into 2 filter open
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) sea lvl
5) What size pilot jets are you using? 45s
6) What size main jets are you using? 390s
8) Do you have a port job? 70-80
9) What kind of carbs? stock
11) Premix ratio? 32.1
1) What type of aftermarket exhaust do you have? t4s
2) What type of airfilter do you have? uni with prefilter
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all airbox no lid
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 700ft
5) What size pilot jets are you using? 25
6) What size main jets are you using? 350
7) What temperature is your Banshee jetted for? winter in ok.
8) Do you have a port job? no
10) What size carbs? stock
1) What type of aftermarket exhaust do you have? FMF Fatty (mine) T5 (hers)
2) What type of airfilter do you have? K&N with outerwear (both)
3) Are you a stock airbox with NO lid (both)
4) What is your elevation? -20 to 250
5) What size pilot jets are you using? 27.5 (both)
6) What size main jets are you using? 270 (hers) 280 (mine)
7) What temperature is your Banshee jetted for? 90F
  • 3 weeks later...
-Dynoport 2 into 1 with Big core Barker silencer
-K&N on Prodesign adaptor with outerwear
-Stock airbox without lid in summer & with lid on in winter (so I don't have to rejet for the colder air)
-Right around 1600 feet (Vandergrift, PA 15690)
-Factory with air screws 1/4 turn in from stock
-290 mains (which is just a little fat, gonna try 280's this summer)
-70 to 80 degree's
-No
-Stock Mikuni round slides
-26mm
I also have 4 degree's advanced timing and V-Force 3 reeds
  • 2 weeks later...
1) What type of aftermarket exhaust do you have?pro circuit pipe and silencer
3) Are you a)running a stock airbox with lid B) stock airbox with NO lid c) Stock airbox with vents d) no airbox at all =b
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 500ft. asl
5) What size pilot jets are you using?27.5
6) What size main jets are you using? 310
7) What temperature is your Banshee jetted for? 30f
9) What kind of carbs? mikuni
10) What size carbs? 26
Thanks!
  • 2 weeks later...
1) What type of aftermarket exhaust do you have? Paul Turner's mid
2) What type of airfilter do you have? Dual K&N's
3) no airbox at all
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) sea level
5) What size pilot jets are you using? Stock, (need to change, won't idle
6) What size main jets are you using? 310's
7) What temperature is your Banshee jetted for? 65-80
8) Do you have a port job? Trintiy
9) What kind of carbs? Stock
10) What size carbs? Stock
  • 2 weeks later...
1) What type of aftermarket exhaust do you have? T5
3) Are you a)running a stock airbox with K&N Powerlid
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) Sea level to 1000ft
5) What size pilot jets are you using? 30
Vito's needle in middle
6) What size main jets are you using? 340
7) What temperature is your Banshee jetted for? 80
8) Do you have a port job? Dune port
Vito's 66mm 10 port jugs at 160psi compression (110 race fuel), Cool head, +4 timing advance. Could go down one or two sizes on pilot as it is a little rich on bottom.
3) Are you a)running a stock airbox with lid B) stock airbox with NO lid c) Stock airbox with vents d) no airbox at all B
4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 800 ft ASL
6) What size main jets are you using? 320
7) What temperature is your Banshee jetted for? 70*
9) What kind of carbs? Mikunis (R5s)
10) What size carbs? 28.5
Edited by RollinRhino
