agnmotorsports
agnmotorsports's Achievements
  1. I will check with a multimeter i will go for a ride and wait until start doing the problem every 15 min of hard ride and check once turn off
  2. I got fmf sst and they work great specially in the midrange and wide open throttle
  3. compression 145 in each pistons
  4. Nothing i got another one that i use for parts i was thinking on change the stator to see if that is the problem
  5. Hi i got a 02 banshee the issue i got is when is cold start right away and run awesome after it been running for like 15 min it dies and wont start until it sit for about 5-10 min and then start right away any suggestions? it will be appreciated!!
  6. i got right now stock pilot with the alba racing needles and 300 main with the sst and mine ran awesome!!!!!
  7. 1) What type of aftermarket exhaust do you have? 2) What type of airfilter do you have? 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all stock air box no lid 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) 995 feets 5) What size pilot jets are you using? stock 25 6) What size main jets are you using? 290 with the stock needle in the 4th clip 7) What temperature is your Banshee jetted for? 290 on summer 300=310 on winter 8) Do you have a port job? nope 9) What kind of carbs? stock 10) What size carbs? stock
