bounty banshee
Everything posted by bounty banshee
  1. I FIXED IT HAD NO PACKING IN SILENCERS SO REPACKED SILENCERS. HAD BROKEN SPARK PLUG WIRE CAP,HAD WRONG GAS MIX WAS 50 TO1 CHANGED IT TO 32 TO 1, PUT A 25 IDLE JET AND A 290 MAIN JET AND PUT TIMING AT +4, MIDDLE CLIP ON NEEDLE. RUNS LIKE A RAPED APE THANKS TO MY NEW FRIEND IN ELDON THANKS CHIP
  2. RUN A 30 IDLE 320 MAIN THTS WHAT MINE WAS SET UP WITH AND IT WAS RUNNIN AT OKLAHOMA DUNES
  3. I RUN A 32 T0 1 MIX , 1 3/4 TURN ON AIR FUEL SCREW 25 IDLE JET, 290 MAIN JET, NEEDLE IN MIDDLE CLIP, AND +4 ON TIMING . CHECK AND MAKE SURE YOUR PACKING IS GOOD ON YOUR SILENCERS IF NOT REPLACE CAUSE MINE ACTED THE SAME WAY AND I DID ALL THOSE THINGS AND NOW RUNS LIKE A RAPED APE LOL
  4. when i take and switch plug wires the miss moves to the other cylinder
  5. carbs are both rebuilt vetos jet kit and slide needles. i know carbs are right now. but if i switch plug wires from one side to the other miss goes with plug wires so what do you all think????
  6. i did switched spark plug boots to other side and it does switch cylinders so could the coil be bad
  7. at wide open throttle falls on its face but i noticed one plug is real wet other plug not so wet like im loosing a cylinder at wide open throttle but if i let off and go half trottle picks back up
  8. thank you for the advice appreciateit
  9. really dont got money for carbs maybe te rebuild will fix it
  10. good idea because he was at the sand dunes before i bought it
  11. im running a 320 main 30 idle jet. my banshee is a 1992 350 falls on its face at wide open throttle in 5th and 6th gear i can let off half trottle and it will pick back up. we ran a compression test and it was 130 both cylinders. got a 10 degree adjustable timing plate set at 0 right now, high output stator ,cpi pipes ,hot rod crank ,bored .60 over mikuni carbs,milled head dont know how much? can anyone tell me anything i need to know? i have ordered a carb kit needles looked bad and i had one float stickin cause if i leave the pet cock on by morning theres gas on floor? please help with any knowledge.we are gonna run a plug test next.
  12. yes you are correct but im in missouri and i need extra clearence
  13. we do alot of trail riding through the woods so the extra height is awesome i know its hard on te joints but it serves its purpose
  14. they are on and it works
  15. my banshee is doing the same thing let me know what it takes mineis messed up
  16. i have a 1992 banshee my buddy said hey i wonder if shocks i got off this honda 400ex would work. so we tried, got them on and liked them they were a little hard to squeezeunder the shock tower but it is awesome suspension i recomend it
