bburg5 Posted October 8, 2007 Report Share Posted October 8, 2007 Alright guys!!! I have a bone stock 1999 Shee. I have just rebuilt the carbs and have 200 mains and 25 pilots (Sent with kit). I then put everything back together and have a bigger problem then what I started with (Leaking thru over flow-"fixed"). It now is very hard to start (Takes starter fluid to start), Once started, I have to keep in the throttle or it dies. As I am hitting the throttle it starts to bog, come up on throttle and spit out the pipes. Noticed today that it runns a little better on chock and smokes out of left pipe more than right. I live in Ohio and want to keep it stock, to just play around on. TORS have been removed completely..... What are the possibilities? Thanks!!! Quote Link to comment Share on other sites More sharing options...
chevy7398 Posted October 8, 2007 Report Share Posted October 8, 2007 did you put the slides back in the right carbs, they will go in the wrong carb and seem fine but wil run like shit, the slash cut in the bottom of the slide should face your filter, if you have them in the wrong carb the will be facing the motor Quote Link to comment Share on other sites More sharing options...
brian Posted October 8, 2007 Report Share Posted October 8, 2007 did you put the slides back in the right carbs, they will go in the wrong carb and seem fine but wil run like shit, the slash cut in the bottom of the slide should face your filter, if you have them in the wrong carb the will be facing the motor Yeah, I did that before. Quote Link to comment Share on other sites More sharing options...
bburg5 Posted October 8, 2007 Author Report Share Posted October 8, 2007 just took it a part again!!! Slides look good and are in the right carb... Slot facing air filter.... Quote Link to comment Share on other sites More sharing options...
shee4speed Posted October 8, 2007 Report Share Posted October 8, 2007 Choke tube installed between the carbs? Quote Link to comment Share on other sites More sharing options...
bburg5 Posted October 8, 2007 Author Report Share Posted October 8, 2007 honestly I do not remember. I have a feeling it was not... Would this have caused all of this??? Quote Link to comment Share on other sites More sharing options...
shee4speed Posted October 8, 2007 Report Share Posted October 8, 2007 yup yup Quote Link to comment Share on other sites More sharing options...
bburg5 Posted October 9, 2007 Author Report Share Posted October 9, 2007 Great that must have been the issue..... I still am getting a little bog when trying to drive off. I have to give it more than what I thought I would have to, to get it moving. What is the cause of this????? Also I feel that it might be loosing power on the top end. what adjustments must I make to correct this? While keeping it stock...... THANKS GUYS! Quote Link to comment Share on other sites More sharing options...
bburg5 Posted October 10, 2007 Author Report Share Posted October 10, 2007 I am still getting the same results as above. The top end seems to spit or back fire when you bring it up to the top. Do I need to increase the main and pilot? Thanks Quote Link to comment Share on other sites More sharing options...
BANSHEEMANIAC Posted October 11, 2007 Report Share Posted October 11, 2007 did you sync your carbs? check your plugs? check your compression? check your fire? i know you took your tors off, but sounds just like this would be your problem. anyway, see if while its running if it runs better or worse with the choke on or off. i wished i had a better answer. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted October 11, 2007 Report Share Posted October 11, 2007 Has the bike run fine since you removed the TORS? You have to disconnect the parking brake wires, the tops of the carb wires, the black box under the left side of the tank, cut the wires going into your thumb throttle...and you did install the idle screw kit on the carbs, right?? Your bike is A1 bone stock, as in stock pipes, stock air filter, stock air box, with the lid and snorkel? What elevation do you ride at, what temps are you riding in? Are you using fresh gas and oil, new spark plugs? Have you done a compression check lately?? Quote Link to comment Share on other sites More sharing options...
bburg5 Posted October 11, 2007 Author Report Share Posted October 11, 2007 Yes everything has been removed (TORS) and has ran fine since. I then have taken the FMF two into one pipes off and replaced them with the stock pipes... The only add on is the K&N filter in the stock box. Idle screws have been installed... elevation is 1025ft and temps 60-85 deg... Has new gas and oil...93 octane and with new plugs No compression check done.... THANKS! Quote Link to comment Share on other sites More sharing options...
RIPRuck Posted October 11, 2007 Report Share Posted October 11, 2007 So everything worked fine after the TORS removal. Than you go from FMF pipes to Stockers, cleaned carbs, rejet to 200 main 25 pilots and put back together. Start the bike and it runs like shit? What was your jetting with the fmfs? Are the carbs sinc? Quote Link to comment Share on other sites More sharing options...
bburg5 Posted October 16, 2007 Author Report Share Posted October 16, 2007 The jets were: 220 mains 30 pilots I checked the carbs and noticed that the right one is slightly lower than the left, but not by much... How do I adjust the slides? Thanks Quote Link to comment Share on other sites More sharing options...
