banshee freak Posted February 7, 2007 Report Posted February 7, 2007 hey guys, just bought a set of fmf rev pipes, they sound awsome but the only thing is that they hit against (what I call) petcock for the fuel shut off. I can only put on reserve now. And even when i put it on reserve..there is alot of pressure on it and fuel seeps out from the little handle. So does anyone know of any aftermarket fix for this??? thanks guys Quote
dajogejr Posted February 7, 2007 Report Posted February 7, 2007 That's crazy!!! Do you have any pictures of this? I've never heard of FMF pipes rubbing or even being close. There are a few inframe drag pipes that are very, very close....but not a trail pipe. Are you sure you mounted them up correctly? Quote
Dinner Posted February 8, 2007 Report Posted February 8, 2007 Yea the only pipes that did that for me was my old DG Pipes :: Never read or heard anything like that for FMF Quote
Olds Eddie Posted February 9, 2007 Report Posted February 9, 2007 Yea the only pipes that did that for me was my old DG Pipes :: Never read or heard anything like that for FMF I've got he same deal. It says FMF on the pipes and they were on her when aquired ten years ago. They looked like they were chrome at one point but have been mostly rusty since I get her. A real pain to work the petcock. I'll proibably upgrade them when I get the $'s. Quote
theshee Posted February 9, 2007 Report Posted February 9, 2007 Never heard of that before, but you may just have to shim it out so it gets away from it. Here is how I shimmed my Shearers... Quote
Olds Eddie Posted February 9, 2007 Report Posted February 9, 2007 Mine dosen't actually hit the petcock. It just makes it hard to get to. I can only use the reserve position or off. I have to wait for the pipes to cool to shut ithe fuel off when hot. Quote
djackbanshee Posted February 9, 2007 Report Posted February 9, 2007 My old DG's did that just buff the petcock a bit on the long side of it so you can put it on on not just on reserve. Quote
Snopczynski Posted February 9, 2007 Report Posted February 9, 2007 (edited) Does the fuel tank come out easily if you have all your plastics off? Or does it have to be forced or shoe horned to get it out or in? Edited February 9, 2007 by Snopczynski Quote
blaster668 Posted February 9, 2007 Report Posted February 9, 2007 Remember guys, he said FMF Rev pipes...they don't make them anymore and are fairly rare. Maybe they are quite a bit different compared to the fatties. Quote
ClimbAnyHill Posted February 9, 2007 Report Posted February 9, 2007 Try raising the tank a bit by using washers under it. I know it doesn't answer your question but maybe will give you the clearance needed. Quote
White06Shee Posted February 9, 2007 Report Posted February 9, 2007 Try raising the tank a bit by using washers under it. I know it doesn't answer your question but maybe will give you the clearance needed. I Was Just Going To say That :: Quote
RNBRAD Posted February 9, 2007 Report Posted February 9, 2007 Shim the pipe out like theshee did. Quote
csrmel Posted February 9, 2007 Report Posted February 9, 2007 99 as everyone else said, you can shim the pipes with flat washers between the pipe mounts and the frame. also put a couple washers under the gastank to raise it up a little. do you have any idea if youre frame is tweeked a bit? id be willing to bet most of the pipe fitment problems people have are due to slightly tweeked frames. Quote
banshee dave Posted February 10, 2007 Report Posted February 10, 2007 I had the same problem with my DG pipes. I don't use them anymore but when I did, I always had it on reserve also. never ran out of gas, but I always checked after a while to make sure I had some. Quote
FireHead Posted February 11, 2007 Report Posted February 11, 2007 Remember guys, he said FMF Rev pipes...they don't make them anymore and are fairly rare. Maybe they are quite a bit different compared to the fatties. Beat me to it. :thumbsup: Quote
