I went riding this past sat. I put new plugs in before going out. Over the winter I installed 34 mm PJ Keihen carbs, new billit intakes without the crossover tube ports, an aluminum intake with K&N filters. I am running RDZ inframe drag pipes with modified DG silencers to be able to run the airbox. I'm not sure of the mains, I think they are 155 or 165 and the pilots are 47.5 I think. I will pull them and check what is in there. I also shortend up the wiring and relocated the cdi under the gas tank. the problem I am having is when I was out riding the right cylinder was running great, the plug was tan. the left side on the other hand was cutting in and out and when the right was running great the left would sound as if it was idleing, i.e the ping ping ping sound of a two-stroke and the plug was black,wet and sooty looking. I am running the timing at +7 but I am going back down to +4. when I got home and started it up I noticed a ton of smoke coming out the left pipe and not so much out the right and the USFS screen on my left sparky was wet looking. The cylinders are ported and they seem to run great when I had the stock carbs and airbox with uni filter. it was hard to start with the stock carbs and wasn't running to it's potential so I upgrade my parts with crappy results . any help would be great
