djackbanshee
Everything posted by djackbanshee
  1. Could anyone who has a j-arm frame close by measure the distance in between the two mounting tabs on the top arm thank you !
  2. No they were new before the runs! But there was gas left in the carbs from the purge .... Would this bit of gas going through make a difference on the plug test ?
  3. . Live from the track . dumped the m5 still revs a little high when I let the throttle down . I give it 1 blip then runs fine all the way back . Plating is a little grey all around up to the first thread would it be considered burnt ?
  4. Got the floats figured out billet bowls had to have the brass overflow tube tweeked a little higher to match stock ones .... also just seen I was given M5 by mistake .. Anybody used that stuff???
  5. having troubles with float level had to lower it a little if I put them where they are supposed to be the carbs leak from the overflow ... Would anyone have a cure to that ?? needle and seat are good carbs are new
  6. no pump would that have an effect
  7. On alky ... Whenever it get to the end of the 1/8 miles when I let the throttle off it hangs and then on the return lane whenever I blip it it kinda hangs . It runs fine blipping the throttle at the start some alky spitting from the pipes , Got the billets bowls . Would it be the pilot jet ? Needle diameter, clip position ?
  8. .176 thank you
  9. Msd
  10. Stock stroke ftz ignition ! What would be the max safe advance timing for alky ? Total timing from tdc in inches ?
  11. Got some on ebay !
  12. no one?
  13. Looking for 68 mm Athena cylinders don't need head or pistons plating doesn't have to be good!
  14. Would you be interested in selling them ?????
  15. looking for virgin stock cylinders low bore !!
  16. I would sell only cases and ingnition for 1500 $ Then you can drop in your lets says 10 mill crank and cheetah cylinders and have a 200 hp 800+cc engine for cheap
  17. Would make a sick engine for the dunes. Is capable of 150 hp the way it is now . Make me an offer
  18. Any questions just ask !!!!!!
  19. It will fit any cylinders with a stock type bolt patern . Either 3 stock cylinders , a triple cub..... . will fit a triple cheetah but you will have to get the cheetah head.. I would love to have it running but i already have enough of one fast bike and looking to buy a hot rod. So it will eventually have to go. Looking for serious buyers.
  20. CYLINDERS OR LOCKUP COVER NOT INCLUDED. Thank you
  21. For sale banshee triple cases , crank , head , 34mm vm carbs , Triple ignition with cdi and coils . Crank has to be assembled . New rods and bearings would be ideal. There is 1000$ of labour just to make the cases ( you can check with many builders ) This engine is not for the beginer , looking for a serious buyer . Capable of 150hp on stock cylinders. Asking 2000$ Thank you
  22. Anyone aware of atv drag races in canada , other than in quebec ? Any fast bikes or only stock bike ???
  23. http://search.ebay.ca/_W0QQsassZdjackbanshee
