Just wondering if it is normal for an engine to have vibrations when idling. When I rev it up it seems to remain in place pretty good. When idling it shakes and even my bikes are shaking.
Is it normal or possibly the crank out of true. The crank is not welded :banghead: and I know you guys might give me sh*t about it. That is next on the list.
Depends on how much vibration u talking about. I know my engine will vibrate the worst right off idle but above that it is smooth. I also have a small vibration at idle but nothing out of the ordinary. From the banshees I have been around they all have vibrated a decent amount.
  • 7 months later...
damm i have the same problem. been noticing that when i rev my bike now it shakes like im riding a dildo with a kick stand.. i just finished cleaning my carbs and noticed it now the most.how do i know if my crank is screwed. i just bought this bike 3 days ago and love it. its an 87 but damm its a banshee.
thats pretty natural for a banshee engine to vibrate at idle. when you rev it up it will seem like its not vibrating as much. ive noticed it too.. unless its really out of control vibrating, dont worry about it.
mine vibrates a fair amount at idle and just above idle it does quite a bit. after about 1/8 throttle it goes away for the most part.
to describe it a bit when its vibrating its worst i can see the spark plugs moving a little over 1/4 inch maybe.
if that describes yours then i wouldnt worry about it. :thumbsup:
It's an 87 without a welded crank????
I'd bet 90% that it's the crank.
I'd flip it on the back tires/grab bar, and look at all the motor mounts real good. Possibly have a rubber bushing shot...which is cheap and easy.
Keep riding a bike with a crank starting to go...you think it'll cost you now to fix, wait till it grenades.
i dont even wana know why he knows what thats like :shrug:
