Slickgib
    so cal
    1987 Red & White,k&n filter .1991 blaster carbon fiber reeds.uni filter.+2 swingarm with holeshot tires.
Slickgib's Achievements
  1. Crank?
  2. Do they still make the kit?
  3. Thank you. I didn't know if i did something wrong
  4. I'm putting my bottoms end back together and I can't seem to get the square key to sit and slide the gear onto it . Any advice ?
  5. Can niche cylinders be rebored ?
  6. Says niche in the guys brand . Heads up
  7. Im tempted to give that kit a try. Probably on my next melt down, But have the port job done somewhere else
  8. Yo , looks to me like the guy grabbed a pair of niche cylinders and ported them.. Check this . http://m.ebay.com/itm/381117616887?fits=Model%3ABanshee+350
  9. It's a resivior for drinking water.
  10. Okay. My current cylinders are at 66mm and I'm just a stocker except for pipes and some vforce reeds . I just don't want to spend 428 for another bore on cylinders that are paper thin. So I'm tempted to get a set. But the old sayin is of it's too good to be true then it probably is .. So who knows . Wonder if the niche cylinders are boreable?
  11. why dont u get a pair of the yfz 450 shocks
  12. Inside ur gas tank there are two sets of filters attached to the petcock. Make sure they are not clogged!also pull ur bowls on the carbs and make sure the jets are not clogged!
  13. For a great engine mod give Doc Brown a call and he can do the dalorian- fluxcopasator mod.. Pretty sweet just jump on ur bike and gun it to 88 and u can go back to the future!!! Hahhaah get a port job man! Some v force reeds are awesome! Mabe upgrade ur suspension
