Slickgib
Everything posted by Slickgib
Do they still make the kit?
Banshee hot rods crank square key help
Slickgib replied to Slickgib's topic in Banshee Repairs and Mods
Thank you. I didn't know if i did something wrong -
I'm putting my bottoms end back together and I can't seem to get the square key to sit and slide the gear onto it . Any advice ?
Can niche cylinders be rebored ?
Says niche in the guys brand . Heads up
Im tempted to give that kit a try. Probably on my next melt down, But have the port job done somewhere else
Yo , looks to me like the guy grabbed a pair of niche cylinders and ported them.. Check this . http://m.ebay.com/itm/381117616887?fits=Model%3ABanshee+350
It's a resivior for drinking water.
- 26 replies
- Oil Injection
- Remove
(and 1 more)
Tagged with:
Okay. My current cylinders are at 66mm and I'm just a stocker except for pipes and some vforce reeds . I just don't want to spend 428 for another bore on cylinders that are paper thin. So I'm tempted to get a set. But the old sayin is of it's too good to be true then it probably is .. So who knows . Wonder if the niche cylinders are boreable?
- 149 replies
- Cylinder
- Cylinder Kit
(and 5 more)
Tagged with:
why dont u get a pair of the yfz 450 shocks
banshee wont start and has brand new topend
Slickgib replied to armando's topic in Banshee Repairs and Mods
Inside ur gas tank there are two sets of filters attached to the petcock. Make sure they are not clogged!also pull ur bowls on the carbs and make sure the jets are not clogged! -
best complete engine kits to use with toomey pipes
Slickgib replied to yukoner's topic in Banshee Repairs and Mods
For a great engine mod give Doc Brown a call and he can do the dalorian- fluxcopasator mod.. Pretty sweet just jump on ur bike and gun it to 88 and u can go back to the future!!! Hahhaah get a port job man! Some v force reeds are awesome! Mabe upgrade ur suspension -
make sure the choke tube is installed.. Its a small black tube that bridges between the 2 carbs! If it isn't there it would be causing the problems your having!
I have an 87 banshee and want to extend the front end out a bit. i have a +4 lonetsar axel. i found a set of +2 +1 DRAG j arms... i dont drag though ..only dune... whill these work or will they just fall aprat?
any body run sand gear paddles? ? ?
how much for a +2 j arm set up? i just got a lone star +4 axel put on my bike and i would like to widen the front sense i do mostly dune riding. i wanna hung them alot better
whats the single best mod for hp and performance gains
how well does your banshee rip. looks like we have alot of the same mods. if i got the port job. and advance the timing -
Yeah i was thinking that proting would be the next thing to do... i have a guy here in san diego that works on my bike. his name is rich yakkey. he did a race port on my brothers banshee and we have all the other same bolt ons but his pulls alot harder then mine... how much is a usual port job -
Ok... Ok what is the single best mod u can do for the most hp-performance gains...I myself when I bought my shee came with a set of T-3"s. And a k/n filter.. So after that I purchased a set of vforce 3 reeds and totally stoked about the gains from them also I threw a cool head and a alum impellar on.. I'm just wondering what I should do next. I love duning it up. So that's what I ride mostly!I'm thinking to upgrade my pipes to some t-5"s or 6"s
also fyi im getting 155 psi of cpmpression on each side.. i have 22 doomes. is this to much. i have a stock motor with toomey pipes and kn filter
yes i ran it alot oiler then usual. but im going to put the head back on and re torque to 22 this time. i only did 20 last time.
i didnt retorque. nor did i rejet anything. i didnt know i would have to rejet after a top end.all i noticed is after it would sit over night and i would start her the next morning she would smoke like some coolent leaked but after 5 minutes of warm up she would run fine. sense i was board when i got home from my trip i pulled the head and noticed the candycane type cylinders.. i torqued it orginally to 20lbs so i hear i could go to 22. so ill re do it. i also wanted to double check everything looked good after the trip i was running pretty hard at some times. i want to install some vforce3 reeds.
