there have been plenty of 2into 1 carb convos. with the 35mm setup are u using more gas then you would with the stockers? i know its an old brought out question but can anyone with the setup tell me if it is worse on gas or not. thanks for any unbiased answers
yes my trinity 2-1 set up uses more gas then my stock set up.when i ride with other stock shees ,i have hade to steal gas off them to get home. so it uses alot more than stock,since they can give me some and still make it home to
i run the graydon setup with a 35mm PWK and get about 2.5hrs on a tank...i never had stockers on so i cant really compare, but i would think you use the same amount of fuel since every intake/compression stroke can onl;y take in so much fiel/air..unless you do engine(compression) mods the feeding system(carb) should put the same amount to the combustion chamber..basically i'm saying it should be the same as stock, or a little more, the benefits of the 2:1 setup are worth it
~Mark~
460302[/snapback]
Are you running long races, scrambles or something? Otherwise, and I don't mean any offense by this, is gas usage a big concern? I can't imagine it would use a significant amount more fuel, and I don't ride my Banshee for fuel mileage, otherwise I'd be on a 4-poke. If you're looking for more bottom end, then the single carb seems to be the way to go, but still the performance advantage you would be seeking to gain would outweight the decrease in fuel economy, in my opinon.
460553[/snapback]
Kinda what I was thinkin--I had the two in one setup and it really sucked the gas... But doesn't everything when you have it pinned all day :shrugani:
RIPPEN
460553[/snapback]
Haulin' Ass = Suckin' Gas, live with it !
is there a big gas diff. between the stock stroke cub and the 4mm?
my buddy's 03 banshee got better gas mileage after the 2 into 1 but its also a 400 stroker. 3 hrs on stock carbs, 5-6hr with the single
