ironhead
About ironhead
  • Birthday 06/21/1978
Contact Methods
  • Website URL
    http://
  • ICQ
    pittsburgh pa
    99shee,4-mill long rod,f.a.s.t dune play port,trinity single 35mmcarb,
ironhead's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. If u realy want good traction, dismount the tire, drill your hole from the outside where u want the screw . Then get 1 1/4 self taping srcews and run them in from the inside out , then run a nut on tight . i will then use a mig welder to tack the nut to the thread so they cant come off. The screws i use are 1/4 in diamiter The set i did has only 50 to 60 srcrews per tire ,but they hook up like your on the street! The harders part is finding the right screw and nut . The self taper screw is a lot harder so it holds up longer . The set i made does not leak at all .no tube !
  2. thanks for your help!!
  3. sorry it was late when i wrote that , its a dgk. how about a 195 main and 48 pilot with the dgk in the middle ?
  4. the needle that came with it, is a GEK do u think it will work ? i think its a leaner needle . I was going to start with a 210 main and a 52 pilot , will that be to rich , im about 800 ft above sea
  5. ok here are my mods jetting wise, - 4 mill long rod - dune port - trinty 2-1,35 pwk,running air box - v-force 3 - noss head 20 cc - t 5s - + 4 timming im just fininshing the build and want to know a good staring point , any help would be great thanks !
  6. post some picks
  7. i just got leager's +1 round housing that im going to run, because ill be trail riding most of the time . im only at the dunes about one week a year . I realy liked the 8 paddles that i ran last year with just pipes, but i wasn't sure if i would benefit from a different tire since its a ported 4mill now , (well when i get my jugs back from jeff it will be). Ill be ordering some soon, just just not sure if i should go up in size or paddles or both. thanks !
  8. i already have a set of 20x10x10 8 paddle haulers should i go with a different size now that its a ported 4mil? Ill be heading to silver lake soon and i want somthing that will be good for all around ridding and maybe some draging . I have to get a set no mater what ,because my girls warrior need paddles. Should i keep mine on and get her a cheap set, or get a new size for me and give her mine? - dune port -4mill -single 35pwk -noss head 20cc -fmf fatties -+ 1 swinger -v force 3
  9. what did u paint them with , hight temp ? were they crome or bare to start with ? thanks
  10. ill be there if the 4mil is done by then ! i wanted to go last year,but didn't make it , how was it?
  11. that does look like rhino linning ! that looks bad ass i like it ! nice shee!!!!!
  12. what size are the 4mill strokers running 35 or 38 ? im in the middle of building a 4mill and debating on witch to go with 35 or 38 . i already have the 2 in to 1 set up for a 33, but i dont think that will be enough with the port work from f.a.s.t.
  13. you could always try some mud sharks , i tried holeshots but went right back to the sharks .they laast for ever and hook up great in the woods.
