fast87
Contact Methods
AIM
Mmarkclark250
Website URL
http://www.skagitsandrats.homestead.com
ICQ
Location
Aberdeen Wash.-Coast
Interests
Quads, paintball...anything worth the effort
My Banshee (optional)
1987 clean banshee, red and white, tons of aluminum=cases and misc. parts, +4" swingarm, graydon nrefs and 2:1 35mm carb. with k&n, ceet graphics, full skid and a-arm skid plates, DG front bumper, toomey T5's, bored .50 over, and more.....
fast87's Achievements
HQ Soldier (2/5)
all of the above, i know it's not banshee related but a set of fabricated aluminum small block ford(289, 302, 351) tall valve covers would be cool, i've been looking for a set for the stang but dont want to pay 200+ for 15.00 in material.. ~Mark~
False Neutral In Almost Every Gear...HELP!
fast87 replied to fast87's topic in Banshee Repairs and Mods
for a little more detail, the bastard wouldent start with a good 20min of kicking, so i had the g/f pull start me, we got a little over 2 blocks distance with it turning over before it fired up, for about the first block the clutch was grabbing but wouldent disengage, like something was stuck...after that it just started working normally again..i probably bent something during all this unfortunately, Thanks ~Mark~ -
about 4-5 months ago i was riding the moses lake dunes with the g/f, then all at once my clutch lever went to the handle bars, i thought broken cable but it was fine, the shaft is moving at the top of the tranny..i let it sit while i worked on my stang, and about 3 weeks ago i pulled the side cover and found the clutch basket very loose, in fact i pulled it right off...the big nut came off(the tab bent back on the steel plate behind it), so i tightened the clutch basket on there as tight as possible with our weak impact and tried to bend the plate around the nut, along with some blue loc tite so it doesnt happen again. Anyway i took it for a ride and all is well(jetting was WAYYY off) except in 1st, 2nd, 3rd and sometimes 4th when i decelerate it will pop into a false neutral..it worked perfectly fine and i've never had this problem with this before so any help is appreciated, maybe i left a spring off somewhere?? Sorry for being long winded, i just wanted to rule out bent parts unless i bent something using the impact wrench.. ~Mark~
yup..i always let it drain for about an hour if i'm not in a hurry, then dump 2 quarts of type F in there, a little extra couldent hurt since there's a vent tube and it helps kep the ball from welding to the clutch rod...usually a little under 1/4" over full on the dipstick, plus the red color is easier to read on the aluminum stick ~Mark~
Q.) Why does a penis have a hole in the end? A.) So men can be open minded. Q.) What's the speed limit of sex? A.) 68 because at 69 you have to turn around. Q.) What does a Rubix cube and a penis have in common? A.) The longer you play with them, the harder they get. Q.) What's the difference between your paycheck and your dick? A.) You don't have to beg your wife to blow your paycheck! Q.) Three words to ruin a man's ego... A.) "Is it in?" Q.) What do you get when you cross Raggedy Ann and the Pillsbury Dough Boy? A.) A red headed bitch with a yeast infection. Q.) How can you tell when an auto mechanic just had sex? A.) One of his fingers is clean. Q.) What do you do with 365 used rubbers? A.) Melt them down make a tire, and call it a Goodyear. Q.) What do bungee jumping and hookers have in common? A.) They both cost a hundred bucks and if the rubber breaks, you're screwed. ~Mark~
i wrap mine fairly tight, you can see the coils..i've jumped a bit and haven't ripped a cover yet, the velcro will probably come undone before that heavy duty fabric tears, so not a big deal to me just put em on and hit the mud! ~Mark~
yeah, any air leaking in after the carb slide...could be the case seals, crank seals, any intake area and i've even heard of some exhaust leaks causing problems...but not likely, anyway check your gaskets for tears, might as well replace them all while you're in there and coat them with ultra grey(not silicone based) before installation, except for head gasket like i said before, leave it dry...with the engine running most poeple spray carb cleaner around the seal areas and if it dies or the idle changes rapidly you have found a leak...good luck and there is little coolant drain bolts on each side of the cylinders, they use a 10mm wrench, good luck ~Mark~
a ring might have caught a port int he cylinder, then bounced around on top of the piston and chewing it up like that...there may not be an airleak but when you put it back together seal everything really well with some ultra grey sealant, except the head gasket, clean all surfaces as best you can with a razor blade then block sand it with 400+ grit sand paper...clean it up really well, remember 90% of the dirt in your engine comes from assembly, so be clean clean clean and you'll have less problems down the road, like crank seals, etc...good luck tho, i had a ring catch a transfer port and screw everything up, i have a set of .020" over jugs that need to be bored to .030" if you need em, and also a like new stock head, used for less than 5 weekends off of a 2005, PM me for details and pics ~Mark~
haha thats awesome, also check out chucknorrisfacts.com ~Mark~
i think a mini swingarm keychain made of billet aluminum would be sick, same goes for a banshee frame, seat or anything like that..maybe some handlebars?? i'd pay a few bucks for something that nobody else has, banshee or quad related that is...hell a mini toyota pickup like mine would be fuckin sweet ass, even if its the size of a hotwheels i'd buy it...all aluminum of coarse, i cant be the only guy here either, good luck ~Mark~
lol i just heard this one on myspace...so i dunno what grade or who this chick is but its pretty funny, lol ~Mark~
I was in biology class once, and the teacher said there is sugar in sperm. A girl asked why doesn't it taste sweet then. When she realized what she said her face became red with embarrasment. Then the teacher said, because you taste sweetness with the front of your tongue, not the back of your throat. The girl started crying and left class ... ~Mark~
i agree somewhat with banshee04le...it's fiber material, try switching to ATF type F only and i bet your problem goes away, mine sure did, the check wal mart 20wt has detergents in it that wear out your banshee clutches very fast...too bad i didnt figure this out sooner..anyway switch to type F and never look back, also aluminum is not magnetic..run a magnet around there all you want and if something sticks to it, it's your tranny, not an aluminum clutch hub.. ~Mark~
a local hardware store like ACE should carry em in those small nut/bolt bins in the back...i've seen em there before, not sure about length but bring in something to measure the threads...i'm pretty sure it's a 8 x .25mm thread but dont quote me on that ~Mark~
try to recreate this sound by rolling it in neutral...make sure its not the chain, pull the head first to see what you can see...if its coming apart anyway it doesnt matter the order you remove parts, good luck and let us know what the problem was ~Mark~
