smokincycles Posted November 4, 2005 Report Posted November 4, 2005 ok,,,heres the deal...i have a 2001 banshee with bad crank bearings...so i want to do a stroker kit,,,timing plate,,,lightened flywheel,,,modified shift star,,,prodesign coolhead,,,,domes depending on crank setup,,,stock carbs in the winter with k&ns no airbox...lectron alky carbs for summer,,,, possible 4 in over swingarm later on,,,we only ride on weekends,,,,normal trails ,hills,down the roads,,,through shallow creeks,,,,silverlake and the badlands,,,i just want to be the one with some roostability...for about $1500.00 to $2000.00,,,,which parts and mods do i want for the biggest bang for the buck.. and the best places to get the parts without getting ripped off,,,.please help before i buy the wrong combo...i need some options,,,.thankyou Quote
badassbanshee479 Posted November 4, 2005 Report Posted November 4, 2005 jeff from F.A.S.T. has all of that stuff on hand and he can do porting for you also, I would say what you mentioned above and a good dune/play port and that thing would fly! give jeff a call and he will work the details out with ya, just tell him what you want it to do and he will make it happen. 785-364-5325 Quote
hittintrees srh Posted November 4, 2005 Report Posted November 4, 2005 Dude, thats a bitchin shopping list!!!!!!!!!! As for you carbs. I got my lectrons from Dennis Packard. His sight is packardracing.com Im sure he'll get ya all set up with some awsome carbs. Quote
RNBRAD Posted November 4, 2005 Report Posted November 4, 2005 4 mil cubs 68mm bore with clean-up port-875.00 Stroker crank-475.00 Pistons, wrist pins and rings-110.00 Timing plate-35.00 from RS Shift star mod- 20.00 Head with domes-275.00 Intake manifold and filters-200.00 For 1995.00, that's the biggest bang for the buck. Carbs will cost you around 3-400 depending on brand and you can recoop most of that by selling your stock juggs . Call Jeff at FAST Racing!!! Quote
FASTOYS Posted November 4, 2005 Report Posted November 4, 2005 jeff from F.A.S.T. has all of that stuff on hand and he can do porting for you also, I would say what you mentioned above and a good dune/play port and that thing would fly! give jeff a call and he will work the details out with ya, just tell him what you want it to do and he will make it happen. 785-364-5325 433105[/snapback] Yep , give me a holler! Quote
odaen Posted November 4, 2005 Report Posted November 4, 2005 Cameron at Redline Racing would be my first pick. Dan from Patriot Racing also has a superb reputation as well. Quote
Ducman Posted November 4, 2005 Report Posted November 4, 2005 RNBRAD has a good list for you. Like he said, it will cost every bit of $2k to get set up like you want, including selling all of the stock parts you can to off set the cost. The good thing is that if you buy everything at once you may get a super package deal if you get it all from one vendor, pluss you get it all set up right the first time at bat. A very good way to go IMO if you got the loot to spend all at once. Quote
broke Posted November 4, 2005 Report Posted November 4, 2005 4 mil cubs 68mm bore with clean-up port-875.00Stroker crank-475.00 Pistons, wrist pins and rings-110.00 Timing plate-35.00 from RS Shift star mod- 20.00 Head with domes-275.00 Intake manifold and filters-200.00 For 1995.00, that's the biggest bang for the buck. Carbs will cost you around 3-400 depending on brand and you can recoop most of that by selling your stock juggs . Call Jeff at FAST Racing!!! 433118[/snapback] You might want to rethink the Cubs, they won't be worth a shit at the Badlands, I rode a set of mildly built Cubs and they aren't even close to what I would want in those tight trails. Quote
blueshee03 Posted November 4, 2005 Report Posted November 4, 2005 (edited) talk to passionre on here or call 918-232-3950 and talk to jim.he's a great guy to talk to and does great work.he will help you decide what setup you want.YOU WON'T BE LIED TO!!!he will also give you the best possible deal he can.you will not be ripped off.we run passion racing's motors and are not disappointed one bit with them or they're performance and durability.jim can beat them prices listed. Edited November 4, 2005 by blueshee03 Quote
