What do all you sand riders recomend for aftermarket sprockets in the sand! My friends have -1 (13) on the front and +3 (44) on the back!
13-44 is not the same as 14-41. No where close. 13-44 is the same as 12-41 and so forth. Most of the guys with mostly stock bikes run 13-41-43. If you do not want to buy a new chain you can get a 13 front and see how you like it. You will not be able to fit a 13-44 on the stock length chain. After you try the 13 front and you decide you like it then buy a new chain and run no smaller than a 14 and just get a bigger rear to match the ratio you want. 14-44 is the same as 13-41. You can look on manufactors of sprockets and see the ratio charts.
315298[/snapback]
My apologies lead, you are correct. I guess I was a little out of it when reading the post.
Nathan
Read my sig.
I use a 14/43 set up, works really nice, can run 4th up any hill, 5th up some, 5th and 6th down the flats.
315428[/snapback]
Do you use stock chain with that set up?
Banshdog you'd be better off running a 14/41 or even a 13/41 with those extremes on there. Banshees hook up on spin and don't like to be lugged. I've found that people that don't use a very aggressive or tall paddle can keep stock gearing. Those out there who actually like some bite to their tires need to drop the gearing a little on a mildly modified shee.
here is the gearing chart again! it is downloadable if you want a better copy email me.
316208[/snapback]
Thanks for the chart! Now I have a better idea of what I want!!!
316347[/snapback]
I was running 13/40 with sand skate II paddles lots of hookup not enough speed and i weigh only 170 lbs so i just slapped on the 14 tooth waht do you guys think. :cheers:
Thanks for all the help everyone! It's amazing that you guys know more than any dealership does! I called aroung asking the same questions and no one knew what the hell they were talking about! LOL! Thanks HQers! :cheers:
