Leadfoot350
Everything posted by Leadfoot350
Got my cylinders back from Porting
Leadfoot350 replied to lambchop's topic in Banshee Repairs and Mods
if you measure the top of the cylinder to the exhaust port and to the transfer ports then guys on here will be able to tell you about the port job. By looking at it I like the flow a lot. He did not go too big on the intake and went for flow and on the transfer tunnels he made them huge which is great. Measure the distance for us and we can tell you what pipes and what rpms the power will come on. -
I have two 35pwk's and I want to convert to a twist. What are the part numbers I need to look for?
Heres a little trick I came up with
Leadfoot350 replied to THE GRIM RIPPER's topic in Banshee Repairs and Mods
I'll stick with my corded milwakee impact and never have to worry about stupid batteries. I hate those things -
who does the cheapest porting?
Leadfoot350 replied to klemet banshee's topic in Banshee Repairs and Mods
I think the time you guys have spent typing and reading all this conversation you could have worked a couple of more hours and had the money saved by now. Honestly porting is worth the money. I just got back from glamis with my 7mm stock cylinder banshee and that thing rips. When the power comes on now its amazing. Kevin ported it for me and Im pretty sure it will run with a 7mm cub or beat it now. I have spent many years and different engine configurations and this one rips. Thanks kevin. -
repack those silencers too. less noise and it goes faster too.
are you fat?
for the filters go to tsracing.com. They sell s&b filters. The one you want is the 8inch long ones that are at an angle. There is only one that is 8inches long so get that one. They also have the outerwears there too. As said before the motionpro cable is the way to go. For the intakes I like the boss ones you find on ebay from in2glamis. I think they are 120 bucks. Get some cel needles and around 155 main jets to get you started.
what size haulers to get for hillshooting
Leadfoot350 replied to blanco25's topic in Banshee Repairs and Mods
From what I have experieced with tires is to buy the ones with the largest roll out. I have seen 22" tires come from 69" roll out to 73" roll out. Thats way too much difference. I bought the 73" roll out ones and they are better for drag racing. I think the biggest they make now for the 22's are 72" roll out. So if you are going to go with a +6 arm I would go with 72" roll out 22-11-8 with 9 paddles extreme super lights. As far as gearing the roll out is going to affect it a lot. Start with stock and see how it pulls the hill -
you could run it that way just make sure the jetting is right for each cylinder and try the two different pipe thing too. The stock cylinder would act like a restricter plate and keep you in check. Too funny
buying a 4 mill stroker crank
Leadfoot350 replied to gmctruck1976's topic in Banshee Repairs and Mods
vitos are turning out to be out of round and should be checked over by a machinest before they are ran. Id go with the hot rods ones -
the critical thing about porting is that the guy who ports the cylinder will do it to match the pipes you are running or atleast thats how it should be done. fattys are a ok pipe but some shearer inframes will add maybe another 6-10hp. They are dune friendly too. I have them on my 7mm stock cylinders that are pretty much a drag port. I dune a lot too!!!!!! Cpi's are good I hear but I have never ran then because they cost so much more money.
I would do pipes with porting. You can do that for 700. Those are the two best bang for the buck mods.
I had a shop do my stock one and they did a pretty good tach job and well it crack the weld so you have to do more than a tach
Its not done to increase the size that much, what its done for is where the cylinder and the top case meet up do not match that well. There is a 1-2mm lip that blocks the transfer air from coming up. So basically all you are trying to do is take the lip out. You can feel it with your finger if you have it apart.
when i split my cases i found this groove
Leadfoot350 replied to bansheejoel's topic in Banshee Repairs and Mods
On the second pic you can see it better. It looks like either you put the cases together with the pin in that spot and when you tightened everything down it made that mark or the bearing tried to sping a little. Either way the grove is tiny and for the groove to get any larger that pin would seriously have to do some digging. Spin that bearing on the crank with your hand and see if it sounds clean and free of grit. If it does put it back together and run it. I have seen far worse cases than that and mine is even worse and it runs fine. -
dont go with any aftermarket clutch fibers. Just look at the ears on them compared to the stock street bike ones. The aftermarket ears look like they are purposly designed to chew up the basket and make you cough up 200+ for a new one. Stick with oem stuff. I use the oem model 4H7-16321-02 straight from yamaha. I have also heard that some guys are running the stock raptor ones too but I have no experiance with those so I can not recomend them. From there you should atleast use 3 heavy duty springs and 3 new stock ones or all 6HD ones.
the penny has to be made before 1973 so its pure copper. Any later and its too hard
if you want to port it yourself go get yourself about 800 dollars worth of porting tools and then we can tell you how to do it. Just let me know when you got the stuff.
You pretty much always tear up the gasket when you take it off. I hate paying 13 bucks each time I take it off. I would buy 10 for 50 bucks if I could. So much money wasted on gaskets.
with my engine I can ride from gecko campground to china wall and race a couple of times then to boardman ville and see the always pissed off bartender lady then to vendor row then to olds and race a couple of times then back to gecko almost hitting reserve. I hear you about the addiction of glamis. Once you go there you wont want to ride anywhere else unless its dunes. As far as degree wheels go you can pick them up at your local hot rod speed shops where all the v8 guys go. I have two and they do not fit over the crank perfectly. One is a motion pro and the hole cam very small and I drilled it out but that is not the way to do it. Maybe measure the treads size that the flywheel nut goes onto and go buy one based off that.
You said it feels like its hitting a false nutral? Try shifting harder if that is the case. Im not too sure we know what are you are exactly saying. You said it revs up like it feels like its in neutral
Ported 4mm or Ported stock stroke
Leadfoot350 replied to gregrob's topic in Banshee Repairs and Mods
I have a 7mm done by kevin and I weigh 215ish. You dont need a lock up. I pulled a blaster out in glamis with Kevin on it. We were trying to get over a hill but there was no easy way around it so I just put it in either 2 or 3 and floored it. When my bike hit the power band damm we took off quick. I have a +6 swing arm too and the front tires were coming off the ground and I had to feather the throttle up the hill. I have the yahama street bike fibers and I think all 6 stiff springs. This clutch is 3 years old too when the bike was a 350cc. I only use the clutch to take off and when I come to a stop so the 6 springs is not and issue and I have gorrilla hands too. -
dont take off your clylinder. Get a degree wheel and we will show you how to check your ports out. Just dont take off your cylinders untill you check the ports. Take the head off though and that 4gallon gas tank of yours. Do you ride to butter cup from glamis or what?
Ya I just tried to go on too and saw I had to pay. Thats not going to happen. I dont believe in paying to talk other people about my interest. Maybe if they shared top secret stuff which they dont so im not going to pay.
a herrjugs extreme dune port and some shearer inframe pipes. Get some pod air filters and you should start winning a lot more races. Porting is the best bang for the buck though.
