Leadfoot350 Posted February 7, 2005 Report Posted February 7, 2005 I basically gear my quad for glamis so that I can pull 5th up olds on the middle of it. The right side of olds will pull 4th. Usually when I get this down then duning is perfect but sometimes could use one tooth smaller on the rear for pulling long wheelies over the up and overs. Gearing is different for everone because of weight, tires, swing arm length, horse power. When I first bought my quad with just t-5's and some 20-10-10 10 paddles extreme haulers I rode with stock gearing and could only pull I think 3rd to 4th but forth would bog. I then put on a 13 up front and it helped out a lot but I really dont remember too well because that was like 5 years ago. Quote
bansheeryder21 Posted February 7, 2005 Author Report Posted February 7, 2005 I basically gear my quad for glamis so that I can pull 5th up olds on the middle of it. The right side of olds will pull 4th. Usually when I get this down then duning is perfect but sometimes could use one tooth smaller on the rear for pulling long wheelies over the up and overs. Gearing is different for everone because of weight, tires, swing arm length, horse power. When I first bought my quad with just t-5's and some 20-10-10 10 paddles extreme haulers I rode with stock gearing and could only pull I think 3rd to 4th but forth would bog. I then put on a 13 up front and it helped out a lot but I really dont remember too well because that was like 5 years ago. 318708[/snapback] I put on a 13 front. Haven't been out to see how I like it. Going out Pres day weekend! Quote
andiefrogger Posted January 11, 2006 Report Posted January 11, 2006 i run a 14/40 and i like it.... in the dunes it works good ... i beat a lot of fast banshee .. my buddys ran all 13/41 ... and i still pulled tons of holeshots up the hill... thats my 2cent not worth much Quote
BigRed350x Posted January 12, 2006 Report Posted January 12, 2006 A 13-44 is the same or equal to a 14-41 which is stock. So there gearing is just wearing the chain faster because of the smaller front sprocket.Nathan 315260[/snapback] That is not the same as stock. You would get a LOT more power from that setup, but not much speed on top. Quote
exclus Posted January 20, 2006 Report Posted January 20, 2006 Just make sure you run "Sidewinder" sprokets and chains. I've watched teeth fly off of renthal sprokets at the dunes. I'm also runnin 14-41 and it seems to hook very well... Quote
Malott 1 Posted January 20, 2006 Report Posted January 20, 2006 On the dune bike I run 15-45. Another place to get sprockets is www.sprocketspecialists.com. Quote
BigRed350x Posted January 27, 2006 Report Posted January 27, 2006 I've never had any of those fancy sidewinder ones, I just run the little steel ones from RMATV and have never had any problems with them. A set of sprockets will last me about 3/4 of a year with normal riding. They are only $9 for front and $16 for rear. Quote
fastbanshee8 Posted January 27, 2006 Report Posted January 27, 2006 I run 15/40 with a stock length chain, and I have no problems at all. It pulls fine in all the gears, but I've got more than just bolt on mods. Quote
bansheeryder21 Posted January 28, 2006 Author Report Posted January 28, 2006 Just make sure you run "Sidewinder" sprokets and chains. I've watched teeth fly off of renthal sprokets at the dunes. I'm also runnin 14-41 and it seems to hook very well... 462034[/snapback] 14-41 is what comes stock! If you ride in sand, run a 13-41 or 13-42. You get way more torque and can hit higher gears going up hills!!! Quote
