Flo Jo
Everything posted by Flo Jo
  1. Flo Jo
    VETERANS DAY
    Ill be out vets day from fri till mon wash 4 any other hq'ers gonna be out and wanna hook up for a ride? Blue 06 LBZ, tahoe trailer, blue and yellow 'shee. I enjoy flowing through dunes and hitting the hill. cant wait to hit up closed areas if they are open by then...
  2. night and day for me. if you havent already call hjr and get a dune port along with tranny upgrades and then you will see what I'm talking about. instant hit off bottom end pulls hard through mid range really shaved off the lightswitch power band to top end and seems like its never gonna rev out just keeps pulling hard fuel mileage suck though...
  3. Flo Jo
    +4 swing arm
    +4 swinger stock shock with eibach spring from mattscs. works good just had to play with rebound and comp a few clicks and i weigh bout 210 with all gear and 220 with my six pack rack full
  4. well it turns out that it was force 3 reeds looked fine but apparently something not right with them put stock reed cages in and it ripped againhttp://bansheehq.com/forums/public/style_emoticons/default/headbang.gif just need to rejet with filters off in the street it rips with them back on its running rough go down on mains or needle?
  5. anybody i cleaned up wiring harness now just what needs to be there and still same thing at high revs sputtering and no power starts and idles fine
  6. can i just ground lights and such to places on the frame instead of running everything back to cdi ground thats also grounded to frame not removing cdi ground just want to ground lights and switches closer to where the molex connector is at.
  7. parking brake has been off I'm gonna go through wiring from front to back and remove stupid wires i don't need maybe a wire is shorted somewhere? and it will get up in speed just no power and hill climbing is non existent.
  8. Ok guys this is the deal i have an 04 banshee with fmf gold pipes 300 mains stock pilots 27.5 i think air screws 2 1/2 out +4 timing .40 wiseco cool head 22cc domes and 135ish lt and 139ish rt cylinder. v force 3 reeds and k&n pods otherwise pretty stock. the problem I'm having is thing will not rev out starts fine and idles good but when you hit it it justs bogs and like backfires the tors are removed have been since 04 this just started i completely disassembled the top end carbs reeds cleaned them out and still nothing. i think I'm chasing an electrical gremlin cause its almost like a tors backfire but nothing has changed. it was running fine till this last trip to glamis last weekend and I've been scratching my head since. any suggestions out there am i missing something?
  9. Flo Jo
    HJR
    So just got my fresh top end from kevin new crank and assorted other things. first off let me say kevin is first class from the first motor i took to him to the last one i just picked up always picks up phone and answers questions doesn't blow you off and explains everything. i thought i had a huge problem and i was worried about new jugs but no worries its back up and running now can't wait to get out to glamis this weekend and destroy some 4pukes!!!
  10. I have the go pro 960 and yes it does beep if you hold the button down you hear it through your helmet. I like it a lot I have used it in the sand at glamis and the water at havasu with the sealed case works great and memories recorded forever. i use it with a macbook pro and for those that don't know the mac has a sd card reader built in much faster than hooking up a cable to transfer data.
  11. Hey guys i have trail tech lights the connections to the lights came off inside. My question is i tried to just hook them up directly to the posts the leads to the lights it works but gets real hot and nearly melts the wires. do i need a resistor or something in line with the power lead from the stator? and what size? any help would be appreciated.
  12. Ill be there veterans for the weekend also.
  13. Went yesterday not much in new stuff but cool to look around and the power probe booth has the OCC chopper on display that was just on tv 2 weeks ago looks better in person.
  14. Aggressive dune port top end so carbs or pipes opinions?
  15. OK I have an 01 with herr jugs porting t-5 v-3 160 comp and +5 timing .040 basic stuff now my question is would bigger carbs im running stockers now. would i get the best bang for the buck that route or CPI's or Shearers? i ride dunes exclusively i ride the dunes hard as well as line up at the hill and drags (glamis). So im thinking of getting a set of bigger carbs and any recommendations on what not to get and what really works and would it be an improvement?
  16. Anybody?
  17. I'm out at Glamis this weekend and my sons banshee starts bogging and losing power at WOT. Pulled the plugs left side is rich and right is lean just started acting up allways ran good. I'm gonna tear apart the carbs and give em a good cleaning I'm thinking it's a plugged main jet. .40 over wisecos fmf pipes k&n pods and +4 timing nothing special just a duner. What do you guys think?
  18. Flo Jo
    GLAMIS
    I'll be on a yellow and blue shee look for chargers bolt on front and grey and maroon shee at olds Friday and sat I'll go to drags on sat eve
  19. Flo Jo
    GLAMIS
  20. Flo Jo
    GLAMIS
    Any one going this weekend? I'll be there Fri-Sun first time out with my new gopro hero cam wash 4 area.
  21. Hey guys trying to get in the ball park of pre load and sag on my +4 swinger. its a dune setup stock rear shock with 8.1 rear eibach spring from matSCESC great guy to work with. just trying to get basic numbers for a all around duning setup. Thanks
  22. Ever lose any shoe laces?
  23. I HAVE 18'S USED LESS THAN 1 HOUR WANT 19 OR 20 COMPRESSION AT 180 WITH 18'S WANT A TAD BIT LOWER
  24. My Shee did the same thing in October this year its under the title AGGRAVATED. :: I finallay figured it out it was a short in the system my key switch was shorting out. I just took it out and soldered the two wires togethor and no more problems. beleive me i was aggravated and i even bought a new stator a waste of 350.00 bones when all along it was my key switch. :verymad: It runs fine now :biggrin: Hope this helps...
  25. Flo Jo
    VETERANS DAY
    I'll be heading out to the flagpole around 10:00 on saturday too from the washes. see you guys out there :biggrin: also from memory so i may be lost for a while down to china wall then west halfway between gecko road hopefully i'll find it. :biggrin:
