I would adjust the timing plate back to 0 advance and play with the Dyna timing curves first. Later if you feel that you need to advance the timing over what they have preprogrammed on the Dyna cdi you can advance it with your plate or take the Dyna to a dyno shop/engine builder to have a custom curve burned.
from what i was told and understand you can not use adj. timing plate or hi output stater with the ds.it will cause it to burn up and the timing plate will just screw up the box.you can get a program for your laptop and make custom adj. to your ds.awsome ignition mod. well worth it.
312267[/snapback]
I hope not. I have a 200w stator on my bike and I just recently installed the Dyna. I've been running it for maybe 5 hours. :shrugani:
if you read the directions they say to use stock stator and you must use resister plugs.
312297[/snapback]
directions, what directions... i got it used.... hehe :)
It should be OK. It is recommended to not rewind the ignition side of the stator. But if you just rewound the lighting side, it doesn't matter.
312666[/snapback]
I think the high output Ricky Stators only affect the lighting coil which won't hurt the Dyna. You should be fine Sredish.
Spoke with a tech named Scott at Dyna and he said there is no problem in running a high watt stator and that racers do it all the time. He said NO PROBLEM.
  • 2 weeks later...
Yeah, my bike has had a high output stator since I bought it. The stator info says its 265W, thats nice. anyway, no problems with my Dyna and the aftermarket stator!
Edited by CombatTalon2
