hamuel Posted September 26, 2004 Report Posted September 26, 2004 I would like to know that as well i run a kevlar clutch in my truck. Thats what everyone recommends for hi-output motors... Quote
SDD Posted September 26, 2004 Report Posted September 26, 2004 From what I read the kevlar particles suspended in the tranny oil causes wear. It supposed to be a problem only on wet clutch systems like what motor cycles have so having a kevlar clutch on a car or truck is no problem. I believe 4 stroke motorcycles have this problem worse than 2 smokers as the particles get up into the cam bearings and wears the whole system out. I think this is a big problem on bikes that do not get regular oil changes. If you read the instructions that come with any Hinson clutch basket they specifically tell you not to use Kevlar friction plates so thats what I do... avoid kevlar. Quote
superchicken Posted September 26, 2004 Report Posted September 26, 2004 oh well i guess ill have to change the oil more frequently now beings i got me a wiseco basket and a hinson pressure plate in her now Quote
23champ Posted September 26, 2004 Report Posted September 26, 2004 My brother has a passion 4mm twelve port. He's running a trinity clutch and has had no problems with slipping or fadding Quote
fixitrod Posted September 26, 2004 Report Posted September 26, 2004 If you read the instructions that come with any Hinson clutch basket they specifically tell you not to use Kevlar friction plates so thats what I do... avoid kevlar. I thought that was only if you used their pressure plate. I guess I was wrong. Quote
hamuel Posted September 28, 2004 Report Posted September 28, 2004 So there is a reason for buying magnectic drain plugs! Quote
fixitrod Posted September 28, 2004 Report Posted September 28, 2004 So there is a reason for buying magnectic drain plugs! I bought my plug at an autoparts store for $2.25. Quote
Bansheerider29x Posted October 11, 2004 Report Posted October 11, 2004 Dirt Digger all the way een since i got it till now i havent see any wear on it yet Quote
tats4life Posted October 11, 2004 Report Posted October 11, 2004 Complete Hinson 8 plate setup with FZR plates and springs. Serious drag motor step up to some straight cut gears as well... avoid kevlar friction plates. i have the eight plate and the kevlar is the only setup i run...........and i've run that setup for about 5 years.........right after i started trashing dr racing clutch kits Quote
lonestar Posted October 12, 2004 Report Posted October 12, 2004 Kevlar will ruin the fingers on your clutch basket. Thats way hinson says to a-void useing kevlar clutch plates. Quote
fixitrod Posted October 12, 2004 Report Posted October 12, 2004 Kevlar will ruin the fingers on your clutch basket. Thats way hinson says to a-void useing kevlar clutch plates. I thought the kevlar wore out pressure plates faster. I didn't know the kevlar would even touch the basket fingers. Quote
Wassup350 Posted October 12, 2004 Report Posted October 12, 2004 I've been runnin kevlar for a few months now and they take a ton of beating before they wear out. Plus the stock basket has worn out and i just filed the fingers down to get the little grooves out and it makes it much easier to clutch and shift. Anyone who is replacing their plates should check out the fingers on the basket because as ive found if there are grooves in them the centripital force will cause the plates to get stuck in the grooves and it wont release as well and it will tend to roll if you have it in gear and have the clutch in. For those of you with money to spare just get a hinson clutch basket. Quote
fixitrod Posted October 12, 2004 Report Posted October 12, 2004 Complete Hinson 8 plate setup with FZR plates and springs. Serious drag motor step up to some straight cut gears as well... avoid kevlar friction plates. i have the eight plate and the kevlar is the only setup i run...........and i've run that setup for about 5 years.........right after i started trashing dr racing clutch kits What year fzr would these plates be for? Quote
roosthrower Posted October 12, 2004 Report Posted October 12, 2004 I ran a tusk clutch kit with ebc springs for a couple months now with no problems with fading or grabing. For the money, the tusk is hard to beat. $40 shipped to your door with everything included from rocky mountain. Quote
Nighty Posted December 6, 2004 Report Posted December 6, 2004 I ran a tusk clutch kit with ebc springs for a couple months now with no problems with fading or grabing. For the money, the tusk is hard to beat. $40 shipped to your door with everything included from rocky mountain. 268382[/snapback] Yeah but once again the tusk kits are not in stock. I've been trying to get a tusk set for over 6 months now. Anyone knows a place to get a kit? besides rocky mountain. Quote
