Building a 475cc class motor.
Has anyone had hands on experience with the 4mm CP Ind 72mm bore DM cylinders for the 472cc? Is it worth the extra money? Or stick with a traditional super cub 4mm 472? Would love advice for do’s and don’t ls. First time building a dedicated class bike. Thanks.
Although I haven't run those exact setups I think I can contribute some solid info backed with my own real world experience.
I'm one of the oldies here with well into the thousands of 1/4 mile passes on a 4mil 421cub, hundreds on a 465 10mil cub and I have a son that ran an almost identical setup with a 392 cub. As you'd expect there's a performance increase with each step. I'm currently in the process of building a 611DM. It uses the same 64mm crank as my 10mil but with a 78 bore but where the big gains come from with the DM over cubs is it's ability to breath much better because of the MUCH larger intake and reeds.
Good luck with whatever you decide
  • Like 2
Call Redline Racing. Cam has some very hard running Super Cubs. I had a 4mm 77 bore that was very strong. I won a lot of shit with that motor. He can set you up.
I'm one of the oldies here with well into the thousands of 1/4 mile passes on a 4mil 421cub, hundreds on a 465 10mil cub and I have a son that ran an almost identical setup with a 392 cub. As you'd expect there's a performance increase with each step. I'm currently in the process of building a 611DM. It uses the same 64mm crank as my 10mil but with a 78 bore but were the big gains come from with the DM over cubs is it's ability to breath much better because of the MUCH larger intake and reeds.
So you would suggest the dm for more air?
Is this a chubby cubby if it’s a 77? I only see 72’s on their site.
4 hours ago, TheKidd said:
Over a 473 DM 4mil? Why? Truly asking.
Torque , it can be done with all. But my 465 @ over 450lb runs 3.6's
It's not how close to 475 you can get... that matters
  • Like 1
Tuned correctly a ported 10mil cub (465cc) is a great setup and will be a far cheaper build than a DM. I agree that it would be worth a call to Cam (Redline Racing). Ask him how the 465 would compare to  https://cpindinc.com/parts/0101-7258-115SA?category=Yamaha_Banshee
  • 1 month later...
