28
Everything posted by Tedder
I agree that a 421 Serval would be the best choice.
Tuned correctly a ported 10mil cub (465cc) is a great setup and will be a far cheaper build than a DM. I agree that it would be worth a call to Cam (Redline Racing). Ask him how the 465 would compare to https://cpindinc.com/parts/0101-7258-115SA?category=Yamaha_Banshee
Although I haven't run those exact setups I think I can contribute some solid info backed with my own real world experience. I'm one of the oldies here with well into the thousands of 1/4 mile passes on a 4mil 421cub, hundreds on a 465 10mil cub and I have a son that ran an almost identical setup with a 392 cub. As you'd expect there's a performance increase with each step. I'm currently in the process of building a 611DM. It uses the same 64mm crank as my 10mil but with a 78 bore but where the big gains come from with the DM over cubs is it's ability to breath much better because of the MUCH larger intake and reeds. Good luck with whatever you decide
With 2.68 straight cut primaries I used TZ's on both the clutch and stator side but with my sustained high rpm 1/4 mile runs light brown color always showed up on the inside races. In never saw any galling but the color obviously indicates skidding and heat buildup. With barrel rollers they have more drag also. I'd pretty much decided on going with Max loads even though they're prone to cracking races if subjected to detonation which I sometimes get with my alcohol motors and they don't have near the TZ's load carrying capacity but for better or worse I ended up going ceramics this time. We'll see if that was a wise decision or not! Personally if I was doing a gas trail type motor I would go either Koyo or Max loads.
Other than two OEM cranks (which are very good quality imo) I've only run Hot Rods in my drag motors under 10mil. Each got upgraded outer bearings from the original Taiwan's. Over the years I've had a few welds crack but never separate like the one in your pic and one large end rod pin that snapped clean through. Luckily it busted when I was doing my dry hop before a run. I've never had a connecting rod snap.
Good place to start would be here: https://www.bansheehq.com/forums/topic/99361-what-jets-are-you-using-fill-out-this-form/ Personally I've done nothing but asphalt drags and mostly alcohol but I'd start with 165 - 168 mains and 52 - 55 pilots.
Grabbed this off of youtube. What you want starts at the 2:00 mark.
I use this on my American Racers (rear) but had to change out the heavy springs to work with light ATV tires and the rim center hole that you have has to be within the balancers cone size. *Can be had on sale or elsewhere for around $65 https://www.harborfreight.com/portable-wheel-balancer-59140.html
On asphalt I've had tire shake caused by excessive toe in. Excessive toe out caused it to wander/dart.
Agree 100% 4mil ported Serval
I can only give accurate information on full drag ported 1/4 mile asphalt cub motors so take this for what it's worth. My son and I did a ton of reed valve comparisons and nothing ET'd quicker than V-Force 2's. V-Force 4's came in a close second and had a better low/mid range pull and would be my choice for anything but an all out drag motor.
Done properly, a plug chop only gives a read of the main circuit at wide open throttle. It's useful to me on my asphalt motors but that's all it covers.
Not sure I understand your question M18. There are a lot of motor and fuel variables but assuming a stock ignition with an adjustable stator plate most running gas are advanced +4 or 5* and those on methanol are 8 -10*
FUEL DELIVERY ISSUE NEED FIXED
Tedder replied to 19Ferro89sheeuser's topic in Banshee Repairs and Mods
Make certain that the pilot jets and circuit is open.- 16 replies
- carburetor
- mikuni
(and 3 more)
Tagged with:
Can't have it all... You need to decide if you want an all out drag setup or not. My son has a very good running 4 and 10 mil ported Serval and I a 4 and 10mil ported cub so I'm familiar with both. From what your post says I'd lean towards the Serval for sure. Redline's an HQ Sponsor and a good choice. Cam will have some good input for you and I'd follow his lead on pipe selection.
- Won't sell individually - I have 2 *BRAND NEW* still sealed in the wrapping Chariot anodized billet clutch baskets with backing plates, cushions and bolts for Banshee's. Buy the pair for $375.00 shipped in the lower 48 only and I'll include 2 *NEW* Chariot ez drain style water pump plates and 1 *NEW* black Chariot water pump cover. Paypal Friends and Family or buyer pay's the fee.
USED TO START FIRST KICK NEED HELP ASAP
Since it fires putting gas through the back of the carbs you've narrowed the problem down a bunch. Focus on the fuel delivery. -
Joe's buried in work now. One man show. He's one of the premier shops out there but you'll wait. I usually use Mark @ R&D Performance. He does exceptional work but is expensive.
I honestly can't tell you on the 4mil. They're custom cut alcohol domes for 1/4 mile asphalt by Tim @ Titan Racing and have no markings. My 10 mil domes were cut by Dave Noss. One pair is 24 and the other 22cc. I'd recommend calling Dave (Noss Machine). He's a sponsor here and has been cutting domes forever. He'll fix you up on exactly what you need.
Pistons stuck in the domes? My 68 bore cubs with 115 rods use 573 series Blaster pistons as does my son's Serval
