I was having an issue with my headlight bulbs blowing out . After some research people said to check a few things with the regulator. after tearing open the wiring harness i found the wrong blue wire was hooked up to it and that problem is solved.. The banshee does have the tors deleted from the previous owner and i think some wires were cut out, but i finally figured out what and where all the wires do and go except for 2 of them as pictured. Cant seem to find them on the wiring diagram either. As you can see there is a connector with a yellow going to a yellow with red stripe. Its hard to tell but connected to that yellow and yellow with red stripe wire is a blue that goes to the regulator, another yellow with red stripe going toward the front (with a solid yellow next to it)and another yellow with red stripe going to the black connector. Then if you look at the yellow and red with the solid yellow next to it that i mentioned before, that must come from the front and work back where it it ties into the other side of that black plug connector and that longer yellow wire looping around with the empty clear connection on it. Don't know what the black connector and longer yellow are for. Bike runs great without them. Just want to know what and if they are needed.
45 minutes ago, locogato11283 said:
It's really hard to see in that picture what's what.
Most everyone here uses the Tapatalk app and then loads pics from there.
Thanks I was wondering how to post a larger pic. I'll repost on there.
Y/r goes to lights
Ok. I'm just wondering what the black plug and long yellow wire that are both disconnected are for.
Sent from my SM-S911U using Tapatalk
1 hour ago, locogato11283 said:
I can;t find that black plug. Do you have low/high headlights? What about taillight?
Yes have high and low. Have the taillight wired but no taillight hooked up.
