Djj624
About Djj624
  • Birthday 06/24/1978
    NJ
  • Interests
    Mechanics
Recent Profile Visitors
Djj624's Achievements
  1. I'm looking for a nice set of wheels(don't have to be perfect) for my banshee. Let me know what you have. Ty Sent from my SM-S911U using Tapatalk
  2. Or sell outright for 700.00 with spare bike to use for parts or resto.. Sent from my SM-S911U using Tapatalk
  3. As title says. Doesn't need a title although would prefer one. Doesn't have to be in amazing shape just as long as it's not rusty, cut, or bent. It doesn't have to be a j arm but I would need a arms and swap my fireball j arms to whomever can supply the a arms. Also I'm working with around 700.00 Thanks Sent from my SM-S911U using Tapatalk
  4. Looking to trade a set of FMF fatties in black for a set of t5s. I'm in North Jersey. Thanks. Sent from my SM-S911U using Tapatalk
  5. Have a 2010 titled moped and another complete parts moped. Looking to trade for a banshee j arm frame or a rear shock, plastics, rims and tires. Ect located in North Jersey. Sent from my SM-S911U using Tapatalk
  6. Looking to trade my red white and blue plastics for a set of black. In North Jersey. Sent from my SM-S911U using Tapatalk
  7. Might I add the bike does run great. Just since the weather got warmer it seems like the idle is a little lower than it was when it was cold.. Sent from my SM-S911U using Tapatalk
  8. Was checking my idle out in the banshee because I thought it was a little low I have the tors delete kit and tried loosening the jam nut on the idle screws (the gold ones on the side) but noticed that the one was pretty much all the way in and the other one was all the way in at a quarter more of a turn. I'm not an expert but it seems that that shouldn't be. How could I reset these or get them to where they need to be? Sent from my SM-S911U using Tapatalk
  9. Just a quick question. I was messing around with the banshee today and decided to check the temperature on each side of the expansion chambers. There is about a three degree difference from one side to another just wondering if that's normal or if they should both be exactly what the other is.
  10. Yes have high and low. Have the taillight wired but no taillight hooked up.
  11. Can I put Amazon 80watt leds like these in or do I have to stick with the stock 35watts? Bike is all stock electrical wise. Sent from my SM-S911U using Tapatalk
  12. Ok. I'm just wondering what the black plug and long yellow wire that are both disconnected are for. Sent from my SM-S911U using Tapatalk
  13. Hopefully this is a better picture. Sent from my SM-S911U using Tapatalk
  14. Thanks I was wondering how to post a larger pic. I'll repost on there.
  15. I was having an issue with my headlight bulbs blowing out . After some research people said to check a few things with the regulator. after tearing open the wiring harness i found the wrong blue wire was hooked up to it and that problem is solved.. The banshee does have the tors deleted from the previous owner and i think some wires were cut out, but i finally figured out what and where all the wires do and go except for 2 of them as pictured. Cant seem to find them on the wiring diagram either. As you can see there is a connector with a yellow going to a yellow with red stripe. Its hard to tell but connected to that yellow and yellow with red stripe wire is a blue that goes to the regulator, another yellow with red stripe going toward the front (with a solid yellow next to it)and another yellow with red stripe going to the black connector. Then if you look at the yellow and red with the solid yellow next to it that i mentioned before, that must come from the front and work back where it it ties into the other side of that black plug connector and that longer yellow wire looping around with the empty clear connection on it. Don't know what the black connector and longer yellow are for. Bike runs great without them. Just want to know what and if they are needed.
