50 minutes ago, locogato11283 said:
Yep.. Way lighter. The pay axles are very durable. I have one on my 06SE bike.
is the play axle still 10+ lbs lighter than stock? or is it just the drag axle that is that light, i saw that the play one is solid not gun drilled
Any tips on how to take an un anodized jja axle apart. All the hubs seem stuck.
Yea, big hammer and wood block or a non-marring hammer and beat them off. Then buy an anodized axle.
Back the bolts out past the split. Put a penny in the split and snug the bolt up again the penny to separate the hub just a bit. Remove.
Ended up getting the mod quad play axle, they had free anodize options, better overall pricing and shipping rates
Very easy to deal with compared to the other venders i contacted
J
U
N
K
That's brilliant. Thank you.
^^ Yes sir but be a high roller and use a nickel
Got to remove the Hub every time you want to change sprockets . should have bought a Jj&a
Jk...yes hubs go out 1"spacer is for brake ( larger 1). take all the sprocket bolts out n u can feed it off , not rotor tho iirc
