jmross Posted August 11, 2017 Report Posted August 11, 2017 (edited) Made the Jump to a high port driveline 4mm setup. I am running 35mm pwk carbs and v force 2 reeds. Am I going to have any fuel supply issues running the factory Kehin bowls and factory petcock? Running pump gas and riding glamis. Thanks Edited August 11, 2017 by jmross Quote
trickedcarbine Posted August 11, 2017 Report Posted August 11, 2017 You will need to at least do a dual pingel petcock and it would be wise to gut the gas cap vent. 2 Quote
rjdgriff Posted August 11, 2017 Report Posted August 11, 2017 You will need to at least do a dual pingel petcock and it would be wise to gut the gas cap vent. ^thisGiving away "TSS" for FREE!!! 1 Quote
Ayesully810 Posted August 11, 2017 Report Posted August 11, 2017 pwk bowls will do just fine I ran the same setup (running stock carbs now) just make sure to run a pingel like the above stated Quote
97Screamer Posted August 11, 2017 Report Posted August 11, 2017 3 hours ago, Ayesully810 said: pwk bowls will do just fine I ran the same setup (running stock carbs now) just make sure to run a pingel like the above stated Why did you go back to stock carbs? I'm building a 4mil and have some 35 PWKs I was going to use. Would I be better off with the 28s I run now? Quote
Ayesully810 Posted August 11, 2017 Report Posted August 11, 2017 (edited) 10 minutes ago, 97Screamer said: Why did you go back to stock carbs? I'm building a 4mil and have some 35 PWKs I was going to use. Would I be better off with the 28s I run now? Depends on what ur looking for. After my build i found that ny motor drank gas AND i was running 110. Not a good combo on a trail motor. So i switched to pump gas ( from 180 psi to 150) and went to stockers. Lost some peak hp and a little torque but who cares? Still 70+ hp and 40+ torque on an unported motor and my gas milage rocks now. Dont be afraid to run the 28s. If u do run the 35s dont set it up for race gas like i did. Edited August 11, 2017 by Ayesully810 2 Quote
rjdgriff Posted August 12, 2017 Report Posted August 12, 2017 Depends on what ur looking for. After my build i found that ny motor drank gas AND i was running 110. Not a good combo on a trail motor. So i switched to pump gas ( from 180 psi to 150) and went to stockers. Lost some peak hp and a little torque but who cares? Still 70+ hp and 40+ torque on an unported motor and my gas milage rocks now. Dont be afraid to run the 28s. If u do run the 35s dont set it up for race gas like i did. With 35s, you're going to get about 6mpg. True storyGiving away "TSS" for FREE!!! Quote
ClaudeMachining Posted August 12, 2017 Report Posted August 12, 2017 Depends on what ur looking for. After my build i found that ny motor drank gas AND i was running 110. Not a good combo on a trail motor. So i switched to pump gas ( from 180 psi to 150) and went to stockers. Lost some peak hp and a little torque but who cares? Still 70+ hp and 40+ torque on an unported motor and my gas milage rocks now. Dont be afraid to run the 28s. If u do run the 35s dont set it up for race gas like i did. Im doing about 30min with a full gas tank (stock tank) Envoyé de mon SM-G935W8 en utilisant Tapatalk Quote
jmross Posted August 12, 2017 Author Report Posted August 12, 2017 Ordered a pingel from f.a.s.t. and will gut the gas cap. I ran 35mm carbs with my drag ported 370 LR engine and I was ok with the fuel consumption. I wouldnt get too far from camp because of it. I hope it doesn't get too much worse with the 421. Quote
Ayesully810 Posted August 13, 2017 Report Posted August 13, 2017 22 hours ago, jmross said: Ordered a pingel from f.a.s.t. and will gut the gas cap. I ran 35mm carbs with my drag ported 370 LR engine and I was ok with the fuel consumption. I wouldnt get too far from camp because of it. I hope it doesn't get too much worse with the 421. Dont worry im sure it absolutley will get worse Quote
STRIBZ Posted August 14, 2017 Report Posted August 14, 2017 Yes i am will Ayesully, i'm running stock carbs with billet bowls just for added insurance.. like stated above depends on what you are doing, if you see yourself holding WOT for extended periods go the bigger carb, if not i would say the 28's will suffice.. enjoy! you will love the cylinders! Quote
RagunCajun Posted August 16, 2017 Report Posted August 16, 2017 On 8/12/2017 at 8:26 AM, rjdgriff said: With 35s, you're going to get about 6mpg. i used to think you were over exaggerating... 1 Quote
rjdgriff Posted August 16, 2017 Report Posted August 16, 2017 i used to think you were over exaggerating...Yeah it's pretty bad isn't itGiving away "TSS" for FREE!!! 1 Quote
bluebanshee98 Posted August 16, 2017 Report Posted August 16, 2017 If your worrying about fuel consumption just bring a extra tank with you via grab bar or whatever you choose. More power you make the more fuel it's gonna use. Quote
jmross Posted August 19, 2017 Author Report Posted August 19, 2017 (edited) Edited August 19, 2017 by jmross Quote
