STRIBZ
About STRIBZ
  • Birthday 12/29/1990
    Perth Australia
  • Interests
    My banshee, fishing camping, anything apart from work.
    lp driveline 421
Recent Profile Visitors
1,342 profile views
STRIBZ's Achievements
HQ Soldier
HQ Soldier (2/5)
10
  1. Mate you should use the search engine as this topic has been been thrashed time and time again.. best way to search is to use google and type for example.... "banshee stock compression bansheehq" Stock compression ranges from 110-125psi.. Oh and welcome to Bansheehq
  2. Cheers mate, i will see if one pops up locally, if not i'll let you know..
  3. Ballajura, Western Australia 6066
  4. how much for stock swingarm shipped to Australia?
  5. if you wanted performance i would look at different pipes, porting, cool head with smaller domes "more compression" the list goes on! You are chasing false hopes in performance with filter v filter.
  6. might be within .5-1hp, like i said you will NOT feel a difference
  7. oh i thought you were talking about a 2 into 1 carb system. i wouldn't think about what one works better for performance you will not feel any difference, i would say it's just which one will suite your needs the most.
  8. i would pick the k&n or the uni as i like the dual carb setup, but that's me. I personaly think you should just save your $$ and stay with stock carbs.
  9. 2-1 carb = tight trails/woods dual carbs with pods = everything else The kind of riding are you doing most will determine what setup should be used.
  10. No worries mate, Depends on what riding you do most the time. i ride 100% dunes so i stick to k&n pods. if you are near water/mud i would stick with an air box. What might work for someone else might not work for you.
  11. like i said with those figures i gave you, you should be a tad "Rich"! the jetting we all gave you are perfect "STARTING" points. you're not going to get your jetting bang on first go, so it's always better to start what you know is rich and work down. You asked for advice and we told you what to do and how to do it! Let us know how you go tuning it. Good luck
  12. i would try middle clip first and go from there. if anything you will be a bit rich, but better being rich than lean.
  13. exactly what i was bout to say! ^^
  14. another thought, if you are going to stick with stock carbs, make sure to change the needle as the stock ones are shit. i use a needle with part no# Y151 and it cleared the carbs up nice! also Toomeys are supposed to be the best for stock carbs.
  15. try this and work from there. 300 main needle middle clip 27.5 pilot 1 1/2 turns on screw.
