So i was riding my bike and at the end of me ride i started to hear a grinding noise coming from transmission it also won't let me shift pass 3rd so my question is ive heard of people splitting the cases and fixing transmission problems before but what are some things that i should be aware of or in tips or tricks that my come in handy 2b190e8a0be7609edddac0a71f2cb27c.jpg thanks in advance
Sent from my SM-N900P using Tapatalk
Take clutch side apart, take flywheel side apart. Take all case bolts out. Then put a tie down or zip tie from the crank end over the head to other crank end to hold the crank into the cyl. Then flip it over and split the bottom case off. Easy
Sheerider, what is it that your seeing that makes you say that? Head being light colored?
Piston wash
The clean marks on the Pistons, the one side has bigger marks so that means more fuel on that side.
