mxturd Posted July 9, 2016 Report Posted July 9, 2016 Just rebuilt everything and wondering what's a good oil to run for the Trans/clutch. Thanks Quote
trickedcarbine Posted July 9, 2016 Report Posted July 9, 2016 Lots of good stuff out there. Klotz, Bel Ray, Etc.... Lotta fellas just run quality ATF fluid. Some is really nice, but the cheaper stuff may need to be changed a bit more frequently though. That said, I like Amsoil Super Shift ATF. Quote
sleeper06 Posted July 9, 2016 Report Posted July 9, 2016 For trail I use Honda 85/80 , drag bikes type f atf changed every track appearance Quote
sheerider11 Posted July 9, 2016 Report Posted July 9, 2016 Walmart type f. Like 3 and change a quart. Change it when your not sure if you changed or last time. Quote
BANSHEE HP Posted July 9, 2016 Report Posted July 9, 2016 mobil 1 5w30 full synthetic or mobil 1 2t Quote
SandSlingerOR Posted July 9, 2016 Report Posted July 9, 2016 I did what hp recommended & non complaints Quote
sheerider11 Posted July 9, 2016 Report Posted July 9, 2016 I've also used rotella to. Cheap for a gallon. Goes in the 450 to do I can use it in both Quote
ClaudeMachining Posted July 9, 2016 Report Posted July 9, 2016 Bell Ray 80w, that oil is made to be used in a banshee like tranny. Quote
jbooker82 Posted July 10, 2016 Report Posted July 10, 2016 RedLine 80wt motorcycle transmission oil here. Its not nice to look at if you have a clear lockup cover. Quote
Tedder Posted July 11, 2016 Report Posted July 11, 2016 Some interesting Bel-ray info here: http://www.belray.com/bel-ray-engine-oil-bel-ray-gear-oil-differences-explained 1 Quote
kennethbrantley5 Posted July 15, 2016 Report Posted July 15, 2016 I use Castro 10w30 Sent from my SM-N910V using Tapatalk Quote
ClaudeMachining Posted July 15, 2016 Report Posted July 15, 2016 Some interesting Bel-ray info here: http://www.belray.com/bel-ray-engine-oil-bel-ray-gear-oil-differences-explained Yup, i dont understand why people use oil who is not made to be use in tranny/wet clutch. Quote
sheerider11 Posted July 15, 2016 Report Posted July 15, 2016 Yup, i dont understand why people use oil who is not made to be use in tranny/wet clutch.Most call for 10w30 And type F is designed for tranny wet clutch Quote
