Flywheel expends on high rpm due to the centrifugal force. If you take off to much material on it, it will for sure weaken the thickness of the wall. If the flywheel has microscopic cracks in the steel, it will be like a ticking timed bomb. My .02 ;)
when is somebody going to add some flywheel weight, dirtbike guys go the other way and add weight to trail/enduro setup 2s bikes and funnily enough they got better power to weight and less rotational mass to deal with
it should help a higher strung banshee motor stay on the pipe especially in a woods situation
could even help in a drag situation, you want to run a bigger tire but you dont have quite enough motor...
  • Like 1
There is a line of dummy's who will be willing to tell you this is assanine. However in my experience, there is a shit load of truth to your theory there. FYI, my 4mm flywheel is weighted...
  • Like 1
I used to add weight to my trail bikes and remove the weight for the track. The weight made it feel like more of a 4 stroke I guess is the best way I can describe it.
  • 2 weeks later...
